301 SAE Bellhousing
T Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Topic: 301 SAE Bellhousing
    Posted: 01 Jan 2024 at 12:45am
Wtb sae bellhousing for 2800/2900 301 motor. Would buy entire unit if needed to get it. I have a IH power unit with a twin disk clutch set up....long story short I would like to replace it in the appropriate orange power.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 8:11am
What size sae housing?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 11:14am
PM sent
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 7:49pm
Your best bet is getting one from a genset. Will likely be a #2
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 9:01pm
I believe it is a no. 2 ...if someone can point me in the right direction as the dimensions to confirm I would appreciate it. Another concern I have is do I need the corresponding flywheel to match up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 9:06pm
Google sae bellhousing size chart. That will show something
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2024 at 9:21am
I have 426 set ups
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2024 at 3:22pm
SAE  Measurements
Edited by JoeO(CMO) - 06 Jan 2024 at 3:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 5:22am
Just throwing this out there- at work we have a bunch of Lull tellehandlers that have what your talking about behind the engine; a few have Cummins, a few John Deeres, even one had a Deutz at one time; the bell housings are very common and maybe alot eaiser to find- have to redrill holes , but anything is do-able
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 8:54am
Most are SAE #2 from what I've seen on the carnival circuit with standby engines. An adapter plate is not difficult to make with a steel plate that bolts to the engine flywheel and a coupler this plate drives and connects the input shaft of the generator to. This assembly does need balanced by a machine shop however or engine or generator section bearings wear fast.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 6:22pm
Thanks for the suggestions.
As close as I can measure at this time....I belive I need a #3 bellhousing.
Building a plate to flywheel conversion will not work in my application because I need the dry twin disc clutch to attach because it operates the disconnect for the machine.
If I can't find an allis bellhousing I will probably suck it up and keep the I.H. motor and overhaul it.
Would the 426 bell come closer to being a #3?
Still looking for flywheel and bellhousing.
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 7:50am
Sent you a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 11:13am
looked at carts I think I have #1 bells and delco 17.75 flywheels with 24 volt starters
 but also have a #3 bell to fit 426 no flywheel or starter
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 11:28pm
The tag is from the power unit and the other two are  301 power units..that is as much as I know about bellhousings.......Dale
Edited by orangereborn - 13 Jan 2024 at 1:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2024 at 11:54am
Is that 433 power unit for sale?
This page was generated in 0.054 seconds.
