190xt brakes |
rw
Silver Level Joined: 28 Oct 2009 Location: United States Points: 383 |
Posted: 26 Nov 2023 at 5:18pm |
The adjuster bolts (3/4 hex) on my XT cant be tightened like they are bottomed out. What needs to be done to lessen the free travel on the pedals?
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4847 |
Sounds like the pads are bottomed out? Have you removed the cover to inspect them? Wear a mask, nasty stuff in there. I replaced mine several years ago due to that issue. Cleaned the balls and ramps also. I have great brakes now. They are external!!! So much easier to work on.
Edited by AC720Man - 26 Nov 2023 at 9:47pm |
rw
OK, should I plan to replace the disks shaped lining and the bands at the same time?
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2257 |
You can shorten the brake rods at the front if you want, but your brake linings are probably about shot and you don't want to have a metal to metal situation. $$$$$$.
rw
Thanks for the input. Ill get it torn down and looked over. I'll put it back together best I can so it will stop good for as long time as possible.
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3646 |
RW...I sent you a message thru the forum here...Rick
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7303 |
You will not know for sure until you open things up and take a look.
