Galvanized rim painting
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Galvanized rim painting
    Posted: 19 Sep 2023 at 6:40pm
My ib rims are in good shape, except the galvanized coating is pocked/chipped. Painting the rims silver shows the unsmooth surface. What works well to make them look better/smoother surface - the remaining galvanized surface is tough to sand off.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:09pm
If your only going to paint portions of the rim, and trying to fill in dimples / rust areas... you might use a THICK cold galv paint like this...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:14pm
If your going to clean and paint the entire rim... i have had pretty good luck with this..
Edited by steve(ill) - 19 Sep 2023 at 8:14pm
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 10:13pm
Thanks Steve.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 10:18pm
I've had great luck with this -
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 10:33pm
Cold galvanizing works well in this application but do allow it to dry thoroughly. It will then sand well and paints over easily. Again, do let it dry thoroughly. Used to do this on communication and navigation towers often. On airfields themselves, they have to be orange and white. If you use a good quality top coat the "repair" will last years.
That's All Folks!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:36am
I have also used that Rustoleum cold galvanizing paint. Seems a little thicker but depending on the pits you're filling may not hide them
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:41am
what I used on the guards on the new idea 30 sickle bar mower . Looks good to me , good choice.
This page was generated in 0.036 seconds.
