OK I give up
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: OK I give up
    Posted: 27 Aug 2023 at 11:23pm
What’s the secret to putting a lightbulb into a rubber mounted stadium light?
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 1:07am
Patience and good lighting in the work space, a small flat screwdriver, a bit of cussing the engineer that developed the stupid concept then put the bulb in the rubber mount first, there is a flat notch on the bulb that lines up with a cutout in the rubber mount, then grab the ladder and proceed to the light bar, hook up the wires to the bulb then you will see the metal cup has 3 or 4 slots cut into it that the "dogs" we'll call them on the rubber mount go into, work them into place 1 at a time with the screw driver while continuing to cuss a bit. I remember putting them things back in after having them bounce out while disking over chisel plowed ground years ago, never come out during the day but wait till you need them at night and there they go. They sure do dress up a 7000 series tractor though. Easy way out would be to go to Larsen Lights and order up a set of LED replacement lights, I have put them on a R62 and several tractors. The folks there are good to work with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 10:37am
Give it a bloody good cursing. I’ll try to remember that. L O L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 10:43am
LoL 😆 LoL I bet I tried 500 times last night. On my third try here this morning it worked. I’m gonna have to try cursing more often. LoL
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 3:07pm
Put a little vasoline on it. Or some kind of lubricant. it will slide right in
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 8:25pm
I use soap for lube, it will eventually dry so as not to collect dust
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 10:35pm
Use rubbing alcohol on rubber to make it slippery; it dries out quickly and won't attract dirt. Works great on rubber tubing, etc.
