Starter Armature Removal |
Dale (Stonelick)
Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 186 |
Topic: Starter Armature RemovalPosted: 07 Jul 2023 at 12:23pm |
I'm replacing a Delco #1107043 starter armature in my Allis B. Trying to remove the old gear, spring and lug to put on new armature that I purchased from Romaine Electric - WI for $65.
The lug (see white tape in picture) is not sliding off easily. Appears that the key should not be a problem. Have been persuading with hammer and block of wood in vice - with lube. Any suggestions? Would trying to expand lug with MAP torch hurt anything? Thinking might be a metal burr in there. ![]() |
1951 CA - 1944 C - 1949 B - Kubota M6800
Joined: 11 Sep 2009 Location: illinois Points: 88671 |
Posted: 07 Jul 2023 at 12:38pm |
hard to get in there and hit with a block of wood... how about taking two 1/4 inch straps and setting between the windings and the gear... turn it upside down and set across open jaw vise... then tap on the end of the shaft......... something like a gear puller..
i dont see why heat would hurt, but a good even distributed THUMP might work.
Posted: 07 Jul 2023 at 12:42pm |
something like this... but if you dont have a bearing puller, two 1/4 inch plates should work.. hold together with tape for a third hand..
Dale (Stonelick)
Posted: 08 Jul 2023 at 8:22am |
Thanks Steve. The two steel plates worked great.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 09 Jul 2023 at 9:20pm |
I used to just use a couple of open end wrenches, basically doing the same thing. Works wonders!
