8010 exhaust manifold
eskinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eskinner Quote  Post ReplyReply Direct Link To This Post Topic: 8010 exhaust manifold
    Posted: 24 May 2023 at 11:40am
We thought we would probably be able to find someone on here to answer our questions better than anyone else. On the exhaust manifold we were trying to find what the tightening sequence is and also how many ft lbs. of torque to tighten too? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 12:00pm
The bolts are a special bolt from AGCO only. Do NOT use the lockwashers they use. Get a hardened Grade 8 flatwasher.  45 ft lbs with lubed threads.
Edited by DrAllis - 24 May 2023 at 5:02pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 8:17am
Doc, does that apply to all 301's or just the 8010?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 8:26am
ALL 301's have a special exhaust manifold bolt that has "self-locking" threads. The hard flat washer is my deal because I've seen too many broken lockwashers over the years and then that blows an exhaust gasket when the lockwasher has fallen out of place leaving the bolt loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 8:41am
Thanks, now if I can just remember this if it ever comes up!
