7050 3 point
Trenthorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Topic: 7050 3 point
    Posted: 27 Apr 2023 at 8:30pm
My 7050 3 point does go all the way up. never really used it till we put our 10ft blade on it and it doesnt go all the way. The top arms are about 6inches or little more from the windows. Cable is new. Just wanted some insight on where to go from here.
1956 WD45, 1970 190xt Series 3, 712,716,917
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 8:32pm
Better re-read what you wrote. The hitch DOES go all the way up?? or DOES NOT go all the way up? ?                    With nothing on the hitch, raise it all the way up. Walk to the back of the tractor and grab one draft arm and lift it up to see if the upper lift arms will go any higher.  A weak back ?? Get someone strong or use a cherry picker.  The lift arms should NOT go 100% to the top, because that is bottoming out the hydraulic cylinder inside, which is a bad thing AND if it is bottomed out, the hydraulic pump is pressurized all the time, which also isn't good.  So, in the end, you want the lift arms to be a couple inches short of being 100% fully up. New control cable?? maybe needs to be shorter if hitch height is truly low. Need the blade to go higher ?? Put the top link in the lower hole on the tractor, NOT the top hole.
Edited by DrAllis - 27 Apr 2023 at 8:43pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 9:12pm
Shorten the 3/8 rod that pins to right lift arm if every thing is properly adjusted.                       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 9:16pm
Dr allis sorry just seen that. The lift works fine but does not go all the way up I can pick the arms up another six inches at least before it hits the top. The inside of the draft arms are just touching the bottom of the top sway block. I tried to attach a picture but it's to big.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2023 at 4:48am
Trenthorn…email your pic to yourself and send it smaller or medium size to yourself and it will fit just right.
Blue Skies and Tail Winds
                          Dana
