210 engine rebuild vid |
Page 123> |
Ron(AB)
Thanks(1)
Topic: 210 engine rebuild vidPosted: 16 Jun 2022 at 12:19am |
https://www.youtube.com/watch?v=IFM0txXtht8
Edited by Ron(AB) - 26 Feb 2023 at 11:27pm |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Posted: 16 Jun 2022 at 6:39pm |
Sleeve Orings installed wrong. Orange Oring goes on the bottom. Sleeve Oring lube that he used I would not ever use. New updated AGCO connecting rod bolts should have been used. Connecting rods should have been turned around with the new slotted rod bearing shells. I doubt that he did that. Harvey engines do not need or use valve guide seals. Camshaft should have been updated to the four inch long grade 8 bolt in the nose to prevent breakage of the camshaft. Front plate gasket appeared to be installed dry, so it will leak someday. New grade 8 hardware with loctite should also have been used.
Edited by DrAllis - 16 Jun 2022 at 6:41pm |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 17 Jun 2022 at 5:47am |
We use Murphy's Oil Soap in the tub for liner orings here at the shop and have never had a problem. Exception is the top filler bad on a 3406 CAT liner, that gets engine oil as the oil causes it to swell and seal. I too noticed the front plate going on dry I wondered about it.
Looks like a nice machine shop. Wish he was closer.
Posted: 17 Jun 2022 at 6:15am |
Lots of nice tooling for sure. My issues with his work on that engine is because he isn't that knowledgeable on the A-C 3000 series engine. I'm sure he has a ton of knowledge, but it isn't on Allis as shown by what I consider to be his mistakes on this OH. As far as the Oring lube, I've experienced piston/sleeve seizure from too much of or use of the wrong lube, squeezing the sleeve too tightly. Only on non-piston cooled engines like that one. I know of an old friend from NW Illinois that had a 7030 apart three times for piston/sleeve scoring after OH.
Edited by DrAllis - 17 Jun 2022 at 6:15am |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 17 Jun 2022 at 7:43am |
Interesting video. Is it normal for the 2nd ring to be broken? |
Posted: 17 Jun 2022 at 8:05am |
Yup. They had issues with that years ago. Pretty common, especially when ether was used a lot.
DonDittmar
Posted: 17 Jun 2022 at 8:38am |
I do my own overhauls of course, but I would let him do my machine work in a heartbeat.
Hindsight is 20/20, but I wish when I a graduated college from NADC, I should have jumped on a plane and took the course at School of Automotive Machine (S.A.M.) in Texas. I wish I had all the knowledge and tooling to do all of my own machine work
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9002 |
Posted: 17 Jun 2022 at 9:40am |
All my 2nd rings and a few top rings were broken when my 220 got tore down. Fogged pretty good out the breather but sill ran good.
Posted: 17 Jun 2022 at 10:08am |
It took them a few years, but they finally changed the 2nd ring material to help with that problem.
DonDittmar
Posted: 19 Feb 2023 at 8:06pm |
An older post, but in following up to the original:
Ron(AB)
Posted: 19 Feb 2023 at 8:50pm |
That's too bad! Pull it apart a 2nd time...
Thanks(1)
Posted: 19 Feb 2023 at 10:05pm |
I have no way to contact them. The problem is somewhat typical with overhaul parts. They had Orings installed incorrectly when they assembled it. They used too much and the wrong kind of Oring lube on the sleeves. Lastly, this engine doesn't have piston cooling and the new overhaul parts need piston cooling because the sleeve/piston running clearance is too tight !! All the sleeves need to be seriously honed to loosen things up .002" or .003" because it may do it again !! By this I mean .002" to .003" removed from the sleeve, so .004" to .006" increase in diameter of the inside of the sleeve. Read my previous posts !!
Edited by DrAllis - 19 Feb 2023 at 10:14pm |
Mikez
Posted: 19 Feb 2023 at 11:23pm |
Dr below the video is a paragraph and at the end says show more. Click that and it drops down some info. Website an email.
That’s kinda interesting.we bought an 8050 that acted weird and would stall. Never really figured out. Found it had cracked block and I bought a whole other engine from salvage. But anyway the cylinders looked like that and was supposed to be a new motor job
Posted: 20 Feb 2023 at 6:26am |
Thanks, Mike. I sent him an email. Hope he hasn't got it back together yet.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5206 |
Posted: 20 Feb 2023 at 8:53am |
So many wrong answers in the comments on the page! Wow! I'm with Dr on this, but also who did the injection work? Seems sketchy at best if they cannot even put timing mark on correct side! The guy commenting about how 24 seems too high doesn't know his @$$ from a hole in the ground about pumps, deere & ih are timed at end of injection so it can be timed at or near tdc. It is simply where the mark in the pump is placed. The AC pumps are marked for beginning of injection, the pump advance is 6*, so 12 crankshaft degrees. So at higher speeds when at full advance we have the 12 plus 24, for 36* total degrees. Most engines will be timed between 28 and 38*. These pumps can be air timed, which a good rebuilder does to verify it is assembled correctly. Apply air pressure to the #1 outlet, turn pump shaft normal direction (cw from front) and it will "lock up" when it is beginning to inject. At that point the lines should align with each other. I've had the pleasure of fixing other shop's poorly rebuilt pumps that do cause premature failures, due to being marked wrong. Sadly the parts often get blamed.
BKarpel
Joined: 27 Apr 2012 Location: Collinsville IL Points: 115 |
Posted: 20 Feb 2023 at 8:54am |
Do you think it is pump related? I was reading the comments. I have ran 40 degrees with EDs pump. Think he locks the advance. To me it looks like pistons got tight. Wish I could find a $500 210!
injpumpEd
Posted: 20 Feb 2023 at 9:18am |
Brandon, 40* is strictly for a pulling Roosa pump with the timing advance locked out. I'd be happy to find a 1000$ one lmao! I do think it's funny he is taking it back to the shop that did it to begin with, they will surely not "find" anything wrong lol! Coers Olivers had a similar issue with a rebuild. It was pump timing mark issue. It didn't look like that chisel pulled hard enough to overload it. Makes me wonder if the engine didn't need rebuilt to begin with. They had the pump rebuilt, then started using it, and it then ended up with a ton of blowby, kinda like this time. I'd say there's a connection here. I don't remember if it was scored cylinders in the original sleeves. I bet it was!
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8781 |
Posted: 20 Feb 2023 at 10:05am |
I just watched a tiktok video on this tractor yesterday. I certainly hope that this guy gets Dr's advice in time to save another failure. I've watched many tiktoks from these guys (father/son) and they seem to be awesome machinists, but maybe need some allis engine building advice. The dad seems to be an allis guy, and I like to see that. They could probably use some advice from Ed also.
Darrel |
Mikez
Posted: 20 Feb 2023 at 11:37am |
Hopefully they will except the advice.
MikeKroupa
Bronze Level Access
Joined: 12 Sep 2009 Location: pierce,nebraska Points: 77 |
Posted: 20 Feb 2023 at 12:15pm |
I've always used JD sleeve soap on liner o-rings. Never have had a problem. Back in the day, while in college, seen a NTC 855 Cummins seize up from a rolled liner 0-ring. It's one procedure that has to done correrctly or it will haunt you., Mike
Posted: 20 Feb 2023 at 6:02pm |
Done a little research tonite on piston skirt to sleeve clearance and will relay the information. From the D-21 service manual: .0065" to .009" (these are numbers I like) from the 210/220 7030/7080 and 8030/8070 service manuals .0025" to .005" !!! NO WAY !! The 210/220 and 7030 engines have no piston cooling and there is no way that .0025" will ever work (and doesn't work) and even .005" is too tight to suit me. I always like .007" or more on any pulling engine I threw together for trouble free operation. So, I also looked at a 6080 engine and a 7010-7020 engine and even they are at .004" to .007" on a much smaller diameter piston. Makes the D-21 numbers look very correct comparing a 4.25" piston to a 3.875" piston !! 301 puller engines with no coolant around the sleeves we shoot for .015" minimum.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34642 |
Thanks(1)
Posted: 21 Feb 2023 at 12:35am |
The 190/190XT manual, (301) lists the ring gaps Top, 2nd & 3rd at .017 -.032" Oil control rings at .015 - .025" and piston ring to groove clearance at Top compression ring .0050 - .0065" 2nd and 3rd rings .003 - .0055" Oil control ring .001 - .003" Piston sleeve running clearance at bottom of skirt, .0035" to .0065" and states no less than the .0035" to prevent premature failure of piston or liner. Going to the service manual for Model 210 - 220... service manual part no. 9003416 in general specifications, Cylinder ID, 4.2495" - 4.2510" Piston skirt dia. 4.246" - 4.247" clearance of .0035" - .005" according to numbers above. But... book lists .0025" - .0050" in the piston section. On page A-125 PISTONS AND PISTON RINGS Inspection, it says: new cyl. sleeve ID 4.2495" - 4.3510" (0.10 larger id bore than above... misprint, the 4.351" dia. should have been 4.251") New piston skirt dia. 4.242" - 4.243" (Different numbers than above) clearance of .0065" to .009" (different numbers entirely) listed in service section ring end gaps top 3 .013" - .033" oil control end gaps .008" - .028" In spec section pages top compression ring .013" - .028" second & 3rd rings .009" - .024" oil control spec .009" - .024" Seems somebody didn't do their proof readings... So what were the real numbers on new piston skirts? Guess as long as there was .005" -.009" gap between sleeve and piston, things would be fine.
Posted: 21 Feb 2023 at 6:07am |
I'd like .009" better than .005" (on a 426 with no piston cooling) and there is no way .0025" would ever work. I agree, someones calculator had a key there was coffee spilled on making it stick. Kind of the same thing when you look up compression ratio numbers for a 200-7000-7010-7020. Always in the advertising literature it was 16 to 1, when in reality it was 15 to 1. Anyway, what I see, this 220 engine failed from tight piston skirts. They responded to my e-mail and realize the orange O ring was in the top groove, which according to Allis is wrong. Reliance told them to install orange on top and black on the bottom, which is wrong. There will always be those who "have never had any trouble with the o-ring lube they've always used". I'm telling you from experience, too much lube or the wrong lube squeezes those sleeves tightly and can cause exactly what this 220 engine failed from !! You don't have to believe it. Just have it happen ONCE and you'll change your thinking !! There is also the possibility that the aluminum piston material Reliance (or anyone else of today) is using has a slightly different expansion rate than the material A-C used 40+ years ago. Which kind of negates original piston skirt specs, whichever spec numbers are correct. Looser (up to a point) is better.
Edited by DrAllis - 21 Feb 2023 at 6:30pm |
darrel in ND
Posted: 21 Feb 2023 at 7:26am |
I'm glad that they responded to you Dr, and I hope that they build a very good working relationship with you, and get this rebuild done right. They are very popular on tiktok, and I love seeing positive allis chalmers content on there, because there are so many allis chalmers haters over there; makes me sick to my stomach. Thanks for all of ypur allis chalmers wisdom.
Darrel |
injpumpEd
Posted: 21 Feb 2023 at 7:36am |
I wonder if the conflicting specs above are one section for new parts, and another section is re-use guidelines? I'm surprised they aren't on this page. This is THE page to be on if you are an AC person!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5192 |
Posted: 21 Feb 2023 at 7:45am |
Just curious What do you recommend for O ring lube, Doc?
jeickman01
Posted: 21 Feb 2023 at 5:22pm |
Just out of curiousity, does AGCO offer parts/a rebuild kit for this engine? That's what I would be looking for if it were mine. Seems to me that you can discuss proper clearances, correct liner packing positions, and the right liner packing lube all you want but it's all irrelevant unless the aftermarket pistons, liners and packings are exact copies and therefore perform exactly like OEM parts. OEM and aftermarket pistons may have the same clearance when cold but not at operating temperature. What about the change in ring material to prevent the typical second ring breakage? Did the aftermarket pick up on that and change theirs too?
Edited by jeickman01 - 21 Feb 2023 at 5:30pm |
Posted: 21 Feb 2023 at 5:31pm |
I've always used Mazola corn oil on sleeve orings. Wipe a thin film with your finger inside the lower block bore. Lightly brush some on each Oring, again lightly. Too much slobbered on the oring and sleeve area can get you in trouble because the excess oil gets trapped between the Orings and squeezes the sleeves, especially when it gets hot.
WF owner
Posted: 21 Feb 2023 at 6:10pm |
Thanks Doc!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 21 Feb 2023 at 8:15pm |
i have been using the jd deere sleeve soap that bottle lasts forever becuase like the doc says you only need to get it all slick to put them realy comes down to to having good clean counter bores
Page 123> |
