WC / WF question
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: WC / WF question
    Posted: 23 Dec 2022 at 5:06am
I am working on one of my WF's.  I'm starting to reassemble, and I have some questions.
Is there supposed to be a seal around the driveshaft between the transmission and rear end (between the two pictures below)?
My other question is about the bearing in the final drive (picture below). How tight should the nut be, that holds the bearing? I have read that you should snug it so there is resistance to turn it, then back it off to the next notch and another place it said to snug it so there is resistance to preload the bearing, Which is right?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 6:01am
I think there is suppose to be a sheet metal cap with slotted holes at a angle that captures a cork gasket.   As for bearings new ones a preload is good, used bearings tighten till resistance then back off one flat, at least thats what I do.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 10:42am
As for the cork gasket, it is no longer available and as far as i know no one has reproduced one. i would like to hear what others has been using here. Possibly Mr. Pfouts has a reproduction available?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 12:24pm
I used a large soft o-ring from my local CAT dealer, worked great.
as for the hub. from the WC/WF shop book -
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 7:13am
I used an O-ring also
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 11:05am
Did you guys use an O ring where the transmission goes into the differential or on the end of the axle?
When I look in the parts book, they list a packing to go in the differential, but I'm not sure if that is around the driveshaft inside the differential or if it goes where they fit together. I am wondering what goes in there (between the top two pictures), if anything?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 11:35am
you can barely see the o-ring down in the bottom of the transmission case snout
has a bit of red RTV holding it in place
Edited by JoeM(GA) - 24 Dec 2022 at 12:05pm
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 4:11pm
Thanks guys!
I will try the O ring. I'm glad I asked!
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 11:33am
The retaining ring, which attaches to the 2 pins on either side originally held in a dense felt seal.  We have these felt seals available.  If you would like to order one, give me a call - 330.569.7037 - Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 4:41pm
I will be calling you tomorrow morning!
This page was generated in 0.516 seconds.
