Roper pump 3600………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Roper pump 3600………
    Posted: 11 Dec 2022 at 8:30pm
Can’t seem to reduce the pressure enough, backed the adjustment bolt out as far as I dare, when closing valve on discharge the engine starts laboring way too much for my comfort level. Hopefully a ‘softer’ loaded spring is available from Roper. Anybody have experience with Roper pumps? This is 2” inlet, 2” discharge.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 9:26pm
Do you have a trash pump you are working with or a suction pump such as used for irrigation? Roper had their name on a lot of pumps, small engines and appliances for many years.
They didn't make everything marketed under their brand name.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 9:59pm
It’s a Roper brand name. Designed for fuels, oils, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 10:07pm
Thanks. I can check with the local oil distributor for any type information. I did not know they manufactured anything to do with petroleum products.
That's All Folks!
