c #5 plow
54f250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Topic: c #5 plow
    Posted: 09 Dec 2022 at 3:25pm
I just bought a 1940s C with a mounted plow -- I believe it is a #5 plow.  I am missing one mounting bar.  The lower front draw bar (connects to the front of the plow tongue) is connected to the upper lift arm by a piece of flat stock steel.  I can make one but I don't know any dimensions.  The bar has one 5/8 inch hole on one end and four 5/8 inch holes on the other.
If anyone has one, I need to know how long the bar is, how far apart the holes are, etc.
I have a manual with pics but no dimensions.
Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 7:00pm
The mounted plow for a C is a B&C Pickup plow not a #5. Asking for something to fit a correct implement will go a long way to getting the correct part.
 The vertical connecting link from the plow drawbar to the adjusting link would be part #309928. I no longer have any B&C plow frame parts around to give measurements. The upper end will have 3 holes.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2022 at 11:29am
My Model C plow is out behind the barn under 3 feet of snow with more snow coming down. If you can wait a (long?) while I will get a measurement for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 9:56am
Thanks.  We don't have snow here -- yet -- but I don't think I'll be trying it out soon.  When you get rid of the snow, I would appreciate it.
Thanks again,
jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 9:59am
Paul,
Thanks for the info. I couldn't find much about this plow -- just a mention of a #5 and #6.
The part number should be helpful.
jim
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2022 at 10:07am
If nobody gets you the dimensions first, I'll measure up my C plow piece when I'm back home in WI over the holidays.  I imagine someone will run out to their barn with a tape measure before that though.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 7:35pm
I haven't forgotten about this.  Are you still looking for this plow linkage info?  If so, the last time I was home I measured mine up, and can text you a pic of a little blueprint so you can build one.  Just let me know, send me a PM with your cell number, or Email me with it.  My info is in my profile.
Jacob Swanson
