Cummins Tractors LONG POST |
Author | ||
AllisChalmers37 ![]() Orange Level ![]() ![]() Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Dec 2010 at 1:15am |
I just got this month's issue of DIESEL POWER and in it (pg 118) there is an article called Swap a Cummins Into Anything. After reading it that got me thinking, could one swap a 5.9 12 valve Cummins into a W series Allis-Chalmers tractor? I have seen several that have had a V8 swapped in but never a diesel. If it could be done I would like to eventually try it on my 1941 WC. The motor in it is shot and since I already have a stock unstyled WC I wouldn't need for it to be origional. I found out that I could pick up an old 12 valve engine for at the most, in perfect shape $2000. I would think that the 1989-1993 (first gen) Cummins would be the best because it is mechanically controlled and they don't have any complicated fuel or timing controls which would end the need for several computers and wiring hookups.
This is just a thought but if it could be done one day it might make a unique show piece. It would be the only WC at a plow day to pull a 5 bottom plow.
Oh, the closest thing that I have seen (on the internet) to this being done is one being put into a Farmall M. The picture below is it.
Sponsored Links | ||
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
AC37, As someone on the site says "anything can be done if it has proper financing" or something to that effect. I do wonder if the WC transmission and rear end would hold up to a 5.9. One of those 3.something 4 cylinder ones out of bread trucks that guys are putting in Jeeps and Broncos might be a better fit and still plenty of power to impress everyone.
Allis Express participant |
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
That version of Cummins I believe puts out 120 horse on the PTO. WC gonna need some triples on the rear and another WC worth of weight to use that kinda power. |
I had thought about the 4bt Cummins but it must have slipped my mind. I don't know any power ratings on them or the engine size but I've been told that a 4bt is like a regular 6 cylinder Cummins without 2 cylinders. Their size would help in a repower and I think major tractor parts would start to go before the motor bogged out. ![]() |
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
You wouldn't be able to keep anything together with that torque off a 5.9, or at least if you turned it up at all.
I do think that the 3.9 4bt would be a better choice as they still put out somewhere in the neighborhood of 140hp stock with turbo and have been turned up to 700hp before. Problem you are going to have is probably height of the motor. |
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
I think the 5.9 would be a nice conversion in a 190XT, not that there is anything wrong with a 301. Maybe 190XT gas to 5.9 Cummins.
I found a 4bt on Craigslist for $2500. That might not be too bad with their rise in popularity. I won't be able to fund this project for a couple of years so I'm just getting numbers and plans.
As for the height issue, a center hood scoop might solve it.
Put 2 WC rear ends together (flipping the ring gear on the front one)with an articulating joint. Add live hydraulics for steering and implement lifting. Then you could spread some of that power out a bit.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Just remember that a 10% increase in torque will cut your drivetrain life in half. A lot of people make engine conversions, but it's more for show than go.
Doubling or tripling the torque will likely cause almost immediate failure if the tractor gets hooked up. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Mark, I believe that only applies if you try to use the available torque. If you have a 500 HP engine in a WC, and pull 2-14's plowing in second gear, there would be no ill effects on the drive train.
Someone in Ia did the articulated WC with a 262 turbo motor from a D19. I've seen it on the Great Iowa Tractor Ride several tiems.
That's very true, but then why do it?? I guess if it's just for show, but there are so many ways to spend several thousand $ and lots of time. I guess I've always been to sensible or something. |
Mark
Maybe this is true, I don't know but then how do the Super Stock pulling tractors make it down the track with the sled and all the weights on the tractor. They are defiantly double or triple the torque and hooked up. |
Partly because their increased hp is coming at higher rpm levels (if both hp and rpm are doubled, the torque stays the same) and the gears in the "stock" tractors are often not stock. |
Mark
Michael Welch ![]() Bronze Level ![]() Joined: 14 Sep 2009 Location: Jasonville IN Points: 28 |
I would like to put a 4bt in a WD 45 to pull. A open class with about 3/8 tread not over 4500 lbs. |
DREAM ![]() Orange Level ![]() ![]() Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Jeremy, I realize the Farmall in that pic may have a Cummins motor, but they did offer an M diesel. At least i'm pretty sure of that. I saw one at a Mccormick dealer in Homer, GA a couple of years ago. Looked pretty factory to me. Kinda liek a WD45 diesel. Lot of things different than the gas model. Someone may correct or confirm. I'm not much of a red expert(or orange, for that matter, I just like them the best.LOL!)
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Indeed they did Dream!If I remember right,they started on gas and switched over to "D" after a lil warming.
The diesel Farmall M was called a MD. |
