Porta-band bandsaw
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Porta-band bandsaw
    Posted: 21 Aug 2022 at 4:13pm
My old portercable died. I tried to fix it but no such luck. It needs several parts and a couple are obsolete.
Been looking at the Bauer at HF.
This isn’t a tool that will ride in my work truck or I’d buy a new Milwaukee.
This is just for my projects in the shop.
Anybody tried one? The reviews aren’t bad.
Edited by Thad in AR. - 21 Aug 2022 at 5:51pm
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 5:20pm
Have seen several relatively new not make it through a job and thrown out. Most are either trigger, or brush/commutator related problems. Too cheap to put any time into for repair so replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2022 at 9:37pm
I dont have one, but your right, the reviews are 98% positive... I would think for normal , around the house it should work out.... A lot of power tool life depends on how hard the tool is PUSHED.. Dont drag it down and pull the full 10 amps and i would think the life would be good.
Like Codger said, switchs seem to be a big problem, with ALL tools.. I have replaced several over the last 40 years.. They get cheaper and cheaper ( construction) as most are made in CHINA.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2022 at 9:11pm
I've got two Milwaukee portable band saws. Worst thing I've ever used. They are more like portable scroll saws. I could never get a straight cut
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 6:05am
re: I could never get a straight cut.
Could be crummy blade and not setup right.
I bought one of China's finest '4by6' bandsaws 30 years ago.Put an 'economy' blade in,BAD mistake, back to 'bimetal blades, since then, every cut  dead true. I bought a spare machine for $100 at yardsale, just in case.
Never had a need for a handheld unit,curious, what does someone use it for ?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 6:33am
Thad, I bought one for a very specific job a couple years ago.  It worked fine, but, literally have a bout an hour on the tool, so I'm not much help I guess.  The job I had pinched and sprung the blade more than once, and I've never gotten around to replacing the blade, so there it sits.
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2022 at 10:49am
I have the HF saw and it works fine.  I built a stand for it and use it a lot.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
