D21 clutch replacement
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Topic: D21 clutch replacement
    Posted: 03 May 2022 at 9:33pm
Has anyone had luck rolling the back half of the D21 away from a blocked and supported front half?
Or is it best to remove radiator, front end casting and frame rails as called out in IT manual?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:41pm
Best to role engine and front end forward.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:56pm
The concert that I see is that the frame rails do not connect to engine plate and the splitting stands I have will not support the engine, I will use an overhead hoist Connected to engine to move the front half forward.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 11:11pm
Splitting stand I used on 8070,I blocked across stand rails and put jack under oil pan to support engine with frame rails.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 7:19am
A wood block under oil will easily support the weight of motor.                  MACK
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 4:31pm
This is what I use alot .On 190 200 180 etc . I got bolts with heads cut off run them bach throught engine plate n side rail and use overhaed gantry
nonetheless ,still dead.
This page was generated in 0.060 seconds.
