D 15 final drive |
Page 12> |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2996 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Apr 2021 at 7:07am |
About a year ago I found my D 15 has a bent rear axle shaft and a chipped bull gear tooth . I now have a good donor that I plan to put new seals , etc in and then swap the final drive out . I'm sure to have questions along the way . Thanks in advance !
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24704 |
While a strong strap sling will support it, I made a steel one, bolts to the FD. Made it easier to get the right height and 'angles' to slide it back in.... I have an overhead beam, trolleys and chain hoists...make the job pleasant.... I will take pictures IF I can find the silly 'jig'...... Jay
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
And new brakes
Thanks Jay and Fred . I did the brakes when I pulled the final drive last year . Have the donor bull gear and bearings out now . Next up is the pinion shaft . So far , so good .
I'm sure you are knowledgeable of this but, you should only do one side at a time. Put it all back together and then the other side.
Yeah thanks John . I'm just doing the left side .
Having a hard time getting the lock ring off the pinion shaft that's behind the brake drum . Anyone have any advice ? Thanks !
Cut it off with cut off grinder wheel. Then use new snap ring. MACK
Thanks Mack ! Didn't think about that .
Seems kinda expensive to me . Agco lists that lock ring for $22 . Still don't have mine off but haven't cut it yet . Thanks
been looking at the drawings, the snapring seems like an 'infernal' one.... maybe 2 slotted screwdrivers, to pry it up ,once you get it started, 'tease' it out of the slot ? Never had mine that far apart..... it looks easier than doing my taxes though..... 4 hrs labour AND I had to pay.....
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5901 |
Jay Those 'F n T' keys do look similar, don't they ! F..N thing. G |
I actually have my favorite son's lock ring pliers . Haven't done the trick yet , but I'll keep trying .
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87939 |
ALLIS did not make snap rings ... they bought them as hardware.. Do the same.
Yeah Steve . Plan to ask Brenda if they have a generic lock ring when I order the bearings and seals . Thanks
ALLIS will charge 5 x as much as you can get one at the hardware store.
ALLIS did not make bearings or seals either.. Edited by steve(ill) - 21 Apr 2021 at 5:14pm |
Have wondered if Napa could match bearings and seals if I have a number ? Thanks
WeisAC2 ![]() Bronze Level ![]() Joined: 02 Feb 2017 Location: Aiken SC Points: 112 |
My favorite son posted a picture for me . Hard to believe that something this size could be bent . This is the good one . Thanks
Jay
That's a nice setup Jay . I'll just use the wide strap I have . I'm still redoing the donor final drive and a long way from installing it . Thanks for sharing !
Finally got the lock ring off . Came off easy after I cut it , like Mack suggested . Now to remove these 2 bearings and the seal . Thanks !
Google Motion Industries store locator. Take your old bearings and seals with and they will match them up. The best 'bang for your buck' in my opinion. |
Thanks , Charles . May check them out if I can ever get this last bearing off .
FYI the seals on the diff case where the axle goes in are National #471765. You can put TWO of them in place of the 'wider' OEM ones. This should prevent oil from getting onto the brake shoes.... Sad thing is I have 2 sitting here in front on me....
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 969 |
The seals Jay mention can also be had as SKF 12458. I only used one per side and had no leaks... been several years now.
I tossed (er, carefully installed...) two in per side on the theory they'd be on 'new' part of the shafting, 2 is better than 1 and ,well, only $4 a piece and I 'hopefully' won't ever have 'wet' brakes again.........
Thanks Jay and Eric . Think I bought a extra seal last time . Now if I can only find it .
2nd drawer down on the left... er. no, 3rd drawer, hmm maybe 3rd on the right no wait, it's on the btm of the right upper cabinet,yeah, a um... dang ! 'someone' removed that cabinet to make room for 'stuff' from next door. sigh...... NOW I know WHY those seals are in front of me !!!
Maybe we're on a different page ? My old seal is National 50055 L 60 . Gonna check the Agco site and see what they list . THANKS !
Page 12> |
