615 Industrial Rear Axle
brisolts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brisolts Quote  Post ReplyReply Direct Link To This Post Topic: 615 Industrial Rear Axle
    Posted: 22 Apr 2021 at 12:45pm
We have a 615 Industrial backhoe and snapped the rear axle (part # 231666). Removed the axle yesterday (both pieces) and now looking for a replacement. We have heard that the D14 and D15 tractors use the same axle, does anyone know if that is correct?
Jim.ME View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 3:40pm
According to the parts books both the D14 and D15 used that same axle.  231666 is the old part number, the current part number is 70231666, you may want to use both in your search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 4:55pm
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 5:55pm
Brian , can you post a pic of the broken axle ? Just curious . I have a pic of mine on my D 15 final drive thread. Thanks and good luck !
Post Options Post Options   Thanks (0) Thanks(0)   Quote brisolts Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 9:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 6:04am
Thanks Brian . Must've taken a lot to do that !
Post Options Post Options   Thanks (0) Thanks(0)   Quote brisolts Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 1:18pm
We were pulling out a stump and being a little too aggressive as we were changing the angle / pulling at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 2:35pm
Pretty impressive that the engine has that much power . Good luck !
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 2:46pm
Allis D-14 Parts Catalog shows that P/N
Page 163, item 15 - BUT for Shuttle Tractors only.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 4:33pm
Interesting.  Page 163 in the D14 online parts books, is related to the Power Director control or Shuttle control.  The Final Drive drawing is on page 173.  I don't see any note on page 174 about the axle being just for a shuttle tractor.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 6:11pm
Jim
I double checked and got the same info.
This Parts Catalog # D40 I downloaded from Grandpas Tractors.
Printed date on Cover Oct. 1961 , after D-14 Model ended.
Has the name Hubert Bradley written on the cover.
Catalog dated Oct. 1961. Axle for reg. D-14 P/N 227522.
I checked D-15 Parts Catalog D-55, March 1966
Lists just one axle P. 131 item 15 P/N 231666
G
Edited by Gary - 24 Apr 2021 at 8:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 7:25pm
I am thinking the on line catalogs are more current than the printed one you are looking at and the numbers were superseded. The ad that steve(ill) posted shows both numbers. What other final drive parts, besides the axle, show as just for a shuttle tractor?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2021 at 7:35am
Back when I had my I-60 TLB, I broke several rear axles. They are the same as a D14/15.  I think the weight of the backhoe is a little too much. Upgraded to a 715 and then the current 715B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2021 at 8:41am
Sounds like axle breaking is common with hoe - broke 3 on my HD4 crawler when I had the backhoe attached to machine - also wore bearing bore in rear housing and had to have them machined
