turbo |
youngorange2000 ![]() Silver Level ![]() Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Apr 2021 at 8:37pm |
will a 426 turbo work on a 301? the 301 is in my 7020 that has been turned up on the pump only reason I ask as the local salvage yard has a pretty nice 426 turbo
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19792 |
Sure it will work, but not correctly. You won't like it, as the spool-up factor will be way too slow.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 7995 |
An out of the box 3 LM may work for you better
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4806 |
NO! A 3LM466 is not a good match for a 301 in a farm tractor!
Gottcha Ed , wasnt sure as he said it was turned up - so scrap my idea !
nick121 ![]() Silver Level ![]() ![]() Joined: 13 Apr 2016 Location: ontario Points: 322 |
Likely not too expensive to get the proper new turbo for it. Then it's sized correctly for the engine and driveability
groundhog55 ![]() Silver Level ![]() ![]() Joined: 26 Apr 2011 Location: nw in Points: 217 |
I have a RAY JAY turbo for a 301, has very few hours on a rebuild. Can have it for $200.00
Problem with a Rajay brand is nothing connects up like an Air-Research. Oil lines and crossover tube all different.
7020's never came with Rajay's if I remember right.
Edited by DrAllis - 19 Apr 2021 at 7:33am |
It would be better to put the 426 turbo on than the 3LM466. I've ran across so many people thinking it would be good, and it has it's place, but on a 301 farm use tractor, it is way too big! The correct turbo for a 7020 I believe is slightly different than the other non intercooled 301's, not sure what is different about it.
