d 17 tire question
elalr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Topic: d 17 tire question
    Posted: 06 Nov 2010 at 1:20pm
im lookin for a set of 18.4 28 tires. i found a set of 18.4 26 tires on massey rims from a combine ( unknown model) and was wondering  if they would even bolt up. if they will bolt up would they be much smaller? hopefully im not the only one on a strict budget and trying to make due with what i can get cheap. thanks in advance
Edited by elalr - 06 Nov 2010 at 1:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 1:41pm
i found out the model on the massey. its a 300 combine. thanks.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 1:43pm
I have tried a D-15 rim (26")  on a WD  (28") and it would not work.
Rim rubs on the upper bolts of the axle bearing retaining cap.
Gary
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 2:26pm
we curently run 18.4 26 off a gleanor combine on a d14 it all depends on the set back of the rims ours work fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 6:37pm
what about the bolt pattern? would it be the same possibly? thanks for the info so far.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 6:57pm
        We have 18.4-26 off of a john Deere with eight bolt rims that fit right on are D17 but they stick out quite far on each side. We also have 16.9-26 on the other D17 on Gleaner Rims and they work good. I think the rims are off a Gleaner E.
                                        John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 7:04pm
thanks i think  i may try them.  my rims are in poor shape. these are good tires and rims for $350 for the pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 10:17pm
does anyone know if i can fit an 18.4 30 tire and rim on it?
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 12:17pm
I have 18.4x30 on a D17 and a 175(new model d17) they work fine, the tall tire will change the gear ratio though
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 1:19pm
My WD45 currently has 16.9X26 8-bolt combine tires and rims on it and it works fine...and yes they stick out pretty much like you set a set of spin-outs set all the way out.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
