Best paint for rims? |
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Feb 2021 at 11:46pm |
I need to paint some rims, both AC and other brands, silver color. Anyone have a good paint brand to use that holds up well?
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5009 |
I use Ford Argent Silver. I think it is very close to the original rim color. I'm sure there are other options that are good, too.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Rustoleum Hammered Aluminum is what I have used. Levels out well when applied with a brush and is quite hard when dry.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8476 |
John,
I would agree with Greg. I like the rustoleum products. I use rattle cans.
We need pictures too! Regards, Chris |
mruhlig77 ![]() Orange Level ![]() Joined: 19 Aug 2014 Location: central Indiana Points: 589 |
I have used Allis grey primer and /or rustoleum paint.....both are easy to match later..If it needs to be shiny...use an aluminum paint over as suggested.... |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1778 |
Agco pearl gray.
Darb210 ![]() Orange Level ![]() ![]() Joined: 10 Jan 2011 Location: Ohio Points: 851 |
rustoleum, painted my 210 wheels & rims over ten years ago & they still look as good as the day i finished them
DIESEL ![]() Silver Level ![]() ![]() Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
I used Rustoleum aluminum, it looks great.
I painted the rims on the 1955 WD45 back in 1976 when I first got it. Rustoleum primer and then their silver paint. They still look OK, but they rotted out from the inside out. Replaced them about a month ago with new rims. I hope these last another 70 years. Oh well kid probably won't be able to buy gasoline in 70 Years.
I painted mine with a product called liquid aluminum. It was had to paint but covered vary well and has held up. https://www.agrisupply.com/aluminum-paint/p/81758/
Edited by Dakota Dave - 06 Feb 2021 at 11:43pm |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
I use CaseIH silver. Real close match. Painted front rims yesterday with rattle can.
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
I had good results with hammered aluminum paint also.
Thanks for all the great advice guys! The project right now is a Ford 6000 that had a bad tire and the wheel was loose on the axle, and the wheel seal was leaking. Decided I shoud fix it all at the same time. Of course the wheel seal is somewhat difficult to find, although I haven't called New Holland yet. CR still makes them but none in stock nearby, $68!
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1488 |
I think the best way is to get it powder coated and not very expensive. But you have to disassemble so a bit of extra work.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3530 |
Dem-Kote spray can paint makes a great Aluminum(silver) paint. Apply it in very thin coats from a 12-18” distance. It’s nozzles allowed 360 degree movement allowing horizontal side to side to vertical up & down spray patterns.
https://www.grainger.com/product/DEM-KOTE-Dem-Kote-Spray-Paint-in-Gloss-6FGH9 Edited by AC7060IL - 09 Feb 2021 at 8:15pm |
I should have said that all my rear rims are now powder coated. Have a real good local place. Still use the CaseIH silver. The raddle can paint job I talked about above was cream and silver front rims.
Who does your powder coating Calvin?
Orange Day Farm ![]() Bronze Level ![]() Joined: 20 Apr 2013 Location: Ontario Points: 51 |
I use mist silver power coat same as Calvin, best overall finish and very durable.
Orange Day Farm
Clint Worron 30' United, 37' WC, 38' B, 41' C&80 Series cultivators, IB, 51' CA, 42' WF, 49' WD,53' WD&cultivators, 57' WD45&33 Picker, D12, D15HC, 180, All Crop 60, 444 baler, etc... |
Sanchez ![]() Bronze Level ![]() Joined: 01 Apr 2020 Location: Alberta Points: 47 |
This wheel was pretty heavily rusted on the inside and needed some cutting and welding around the valve stem. After the repair I had it galvanized at a local shop . I'm pretty happy with the result, the chemical process removed the rest of the rust and restored the factory finish.
That’s real nice. I believe they were galvanized from factory.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3915 |
That looks real good and will last a lot longer than paint!! Which shop did you use?? I've got a couple from a 'B' I need to do.
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1052 |
Had mine sandblasted and powder-coated. Immediately after sandblasting, I took them to the powder-coating place. I don't recall the exact color; it was some silver that the fellas at the powder-coating place had a "chip" of. The powder coat cost was very reasonable at $80 for both rims. |
Great work guys. I’ll have to inquire locally about powder coating. Your $80/rim seems reasonable. Thanks for sharing,
The shop in Edmonton is Daam Galvanizing, their minimum charge is $90 for 100 LBS, so 2 rear wheels from the WD45 are pretty close to that . As rusty as mine were I figured I would need to sandblast prior to paint , in order to galvanize I wire wheeled the heaviest rust off, then the chemical treatment took care of the rest.
DCAC ![]() Orange Level ![]() Joined: 20 Oct 2018 Location: east central SD Points: 511 |
That's an awesome looking D17!!!
Good looking rims and tractor! John and all of us are getting some good rim options. The take it all apart, repair and sandblast is the best starting point for the coatings. I like the powder coat look on the D17, more of a argent color.
Regards, Chris
