D 15 engine removal
 Rating: Topic Rating: 1 Votes, Average 1.00  Topic Search Topic Search  Topic Options Topic Options
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 engine removal
    Posted: 24 Jul 2020 at 3:20pm
Trying to pull the gas engine out of my Series 1 D 15 . I'm at the roll shift axle removal part . Is it the same as Dr Allis said for the D 17 ? Never done this before and I wanna do if safely . Thanks !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 4:00pm
I have the four 15/16 bolts facing the front and the four 1+1/8 bolts facing the rear broken loose . Had to use my 4' cheater to do this . Next is putting a jack under the bellhousing ? Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 4:38pm
I wedged 4by4 blocks at the tierod ends to keep the front wheels from going cockeyed twisty and causing a potential nightmare.....
the big trick is to use solid wooden blocking for supports and to be very careful.
sure helps to have an extra pair of hands and eyeballs on the job too !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 6:13pm
Thanks Jay . Favorite son is coming tomorrow . We should be able to get it done .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 11:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 11:47am
Fav son posted a pic for me . Dunno why it's kinda fuzzy . Got the front end rolled out of the way fairly easy . Thanks to Dr Allis . Also wedged a couple short 2 by 4's on top of the axle under the nose/chin center piece . Thanks Jay .
Edited by ACinSC - 25 Jul 2020 at 11:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 1:09pm
Where do you fellas attach a chain to the engine to pull it ? Last engine I pulled was a Chevy small block and we used the intake manifold bolts , I think . Would these 3/8" valve cover studs will work ? Thanks !!
Edited by ACinSC - 25 Jul 2020 at 1:11pm
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 1:32pm
I've pulled a few by the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 2:52pm
Thanks Don . Can't imagine this little 4 cyl engine is too heavy .
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 11:36am
I see my fav son has posted more pics . Pulled the engine this morn . Next I need to inspect the clutch . Gotta be a greasy/oily mess , everything else is . Thanks for looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:37pm
For a clutch job, one normally splits the tractor at the bellhousing and leaves the engine bolted to the side frames and leaves radiator and power steering lines and front support still installed..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:53pm
Wanted to pull engine as I have a bad oil leak at the rear of the motor . Gonna put it on my engine stand and flip it over and replace rear main seal and oil pan gasket and anything else suspect . Guess it all comes out in the wash .Be nice but don't have power steering .  Thanks Dr Allis
Edited by ACinSC - 26 Jul 2020 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 7:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 6:00am
Surprised my clutch worked as well as it did. Fiber disc is gone . Metal to metal . Thanks for looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 6:08am
At least YOU didn't find the mother of all 'Mouse house' when you split it !!!! Troy's bellhousing was so jammed full, it took me 2 HOURS to get most of the 'stuff' out..clutch was history, stater,once cleaned actually kibda wanted to spin, a bit, sortof....
You should install a new 'pilot' bearing..... more to the 'list'.... lol
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 6:25am
The correct clutch disc for a D-15 isn't fiber lining, but what you have....4 metallic buttons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 8:55am
Yeah Jay , a new pilot bearing is on my list . Yeah Dr Allis , my disc has the 4 buttons . Just shows how much I don't know . I was going by the pic in my DJ's catalog . I've been in contact with Rick . Maybe he can keep me straight ? Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2020 at 3:51pm
Anyone pulled a D 15 release bearing lately ? Looks like you pull the vertical shaft clip and the shaft pushes out of the way ? Mine's a greasy mess , gonna let it soak overnite .  Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2020 at 3:56pm
yeesh been too long ago tore member that BUT I do KNOW that it HAS to be on the clutch side of a cast iron peg on the driver's side of the bellhousing otherwise YOU get to split the tractor, again, to put it on the correct side of that cast iron peg...
it also took me HOURS to get rid of the mouse house....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2020 at 6:23pm
Sure don't want to hafta do this over Jay . I'm taking it slow and trying to take lots of pics . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 12:33pm
Had my flywheel turned this morn . Guy pointed out 3 evenly spaced  ring gear wear spots . Said he'd seen that before . Maybe because the engine usually stops in the same 3 places ? I dunno . Fav son should post a pic soon . Thanks !
Edited by ACinSC - 29 Jul 2020 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 12:40pm
You can warm the ring gear up and slip it midway between wear spots if you're cheap VS replacing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 1:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 2:03pm
Thanks , Steve . I am kinda cheap .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 3:07pm
gee that's purdy !
mark where ringgear is now, remove, install maybe 60* off ?
4 cylinder engines always stop 1 of 2 places, so I've been told.
new ringgear from Agco,decade ago was $100 Cdn... made in India.
you're not cheap, you're frugal, heck I give all my Dutchies a bad name as I'm frugaller than ALL of them combined !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 3:09pm
Loosened bolt that holds clutch fork together and spread it apart enough to twist the shifter tube and remove it and the release bearing . Have the release bearing knocked off the tube also . Making progress . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 8:30pm
take lots of pictures ! That way you'll have pictures to look at when you do it to #2 and #3 a few years from now.....Wink
