Fat Allis Let me Down |
Post Reply | Page 12> |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29910 |
Posted: 14 Jul 2020 at 1:13pm |
AGAIN. Seems the old gal just demands attention.
Dragged BILs old rust bucket out of the weeds to get running again, will start and run on dribbled gas into throat but fuel pump not pumping gas to carb. Had to use Allis to drag it out as had taken a 'Set' so to speak and my pickup would not do it. Noticed the right brake headed to floor, adjusted it and now all gone. Back to several years ago, likely snatched a shoe apart and I did have the Power Boost dialed nearly off on BOTH sides so may just have been cracked finally gave up. Started tearing the donor apart for those brakes and clutches, will have to pull the cab guard off the runner then get back into the shop to pull the right side brake/clutch out. Last time: |
Something is afoot with images:
Edited by DMiller - 14 Jul 2020 at 2:03pm |
Mactractor
Orange Level Access Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
You maybe right Dave. That machine just likes laying around your workshop. All components will stay freed up that way I guess.
So far seems all its good for!!
Picked up a electric fuel pump for the Chevy 70, will try to get that monstrosity moving anyway, need to haul dirt!!
Got pump connected this morning still no gas, Tracked back to Standpipe in tank rusted off, while under it for that found three sections of brake lines rotted out and dripping, PS will no longer hold oil either. Suspect this one is a done deal and scrap now.
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
fix it and haul your dirt
HD3
Could easily drop a grand in this just in pieces and no real value in it as the cab will fall off, be good money after bad. Stepped on clutch was final determination as the left cab corner lifted and clutch I do not believe really released, mounts are rotted away. Friend of mine THINKS he has another 70 series available to transplant some of the mechanical stuff to, will know some time this weekend, that falls thru this one gets hauled away and start over.
Alright you guys and I have shamed myself into looking first for a replacement square body, may have one north of here, going there in morning. He does have a Runable(Needs carb work) 1977 C70 366 5&2, Hyd. Drum Brakes, sitting on yard Cab and Chassis for $2250 and is Clean machine, a little too much for what we already have. Has several old cabs in various states will negotiate on prices tomorrow. If go that route, will strip the sheet goods off, and then proceed on the brake tubing issues. That far I will reseal the Saginaw Dual Piston and maybe even buy a reman P/S pump for it. How bad it can be or get is anyone's guess.
Mactractor
We all need that sense of adventure you have.
Finally BACK in the Shop. Will be a few days shifting pieces, then can see inside the brake compartment to ID what broke.
As expected, right lower shoe peeled. All torn down, parts stripped from donor, will inspect replacement pieces for the install TOMORROW. Soaked TWO t-shirts today by NOON! It has just hit the Beer Thirty Bell!
Edited by DMiller - 27 Aug 2020 at 1:12pm |
Thought Y'all would like to meet my Helper, tends to not speak much thats OK, just always laying down, have to notch him up once in awhile!! Thinking he is more into Binders!!
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9773 |
Yes understand the soaking two shirts. It's 92 here with heat index of 112, sure would be nice tyo get some rain , it keeps missing us the other day my son live about 12 mile away said he got 1/2" of rain and we got 6 drops. supposed to get some rain tonight or tomorrow and the temp drop into the 70s for Sat**day
Humidity has been something awful here, 80-90% is typical, may as well be raining as soon as I get outside break into a sweat. Can feel for ya!!
Got clutch and lower shoes back in all bolted up and then fought with upper shoe to the adjuster drive for over an hour
Had to just walk away awhile Will get back at it Monday once temper tempers out!! That was yesterday and still mad as well a few bloody spots nicked on sharp edges! Edited by DMiller - 29 Aug 2020 at 7:17am |
Have also decided the yard north of here has some relatively decent old cabs, going to go pick out one for the yellow dump truck once 7G is completed this time. Fully intended on fixing it up but been so frustrated by the 7G as to have to get them both done and GONE!!
All back together this morning, just in time for Tornado Warning T-storms. Cage still in yard, got started looking over trans leaks dropped belly pan, just seepers all over, nothing defined Leak. Need to add a drain hole in pan so does not accumulate to puddle.
The Victim Edited by DMiller - 12 Sep 2020 at 9:56am |
Fat Allis, contemptuously happy to handle the competition.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
Breaks my heart to see green planted in a pasture......lol not
NomoreJohnDeere
Thanks(1)
I dropped the front end of my tractor in a sink hole a couple years ago.
Had to call a wrecker Good your up a going again |
HD3
An additional trip under the seat this morning, seeping leak like to driving me NUTS. FINALLY after leaving sit and I suspect at just the right angle it showed out. Left brake actuator to clutch/brake cover plate. All bolts were tight and the boots intact on the housing flares so peeled the culprit off. Had NOT been off since I replaced the brake on the left along with the clutch actuator seals some seven years back. Evidently in working in the barn, poor lighting and no way to control dirt I allowed a small rock or other piece of detritus to get under the actuator housing when reinstalled it, about .020-.030 thick mashed. Seepage was off and on dependent of speed and percentage of brakes use. Cleaned it all up, replaced the housing to plate Oring on the dump port and then went about backing off the brake pressure just a Tad more adjusted brakes and reset rail slack tension. Ready for tomorrow. This was taken going back in.
Mactractor
There's always something on these ol gems to keep us on our toes. Your perseverance has to be commended Dave.
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
Are you still serious about sending it down the road after finally getting more bugs out of it? There has been more then one piece of junk I got so frustrated with trying to repair but then after I got it working, I kept it because I figured it would be hard to find another, probably in no better condition.
Actively listed CL locally and on Machinery Trader
Time for FA to see a new home |
I will explain a tad further. In mid sixties now, the 20# pin pusher and I no longer deal well with each other nor do the off angle approaches to repair regions does my arthritic spine and hands deal with very well. Knew was gaining age when could not twist into the contorted shapes I once could to make repairs I used to do offhand. Age our Constant companion is NOT our friend where while Allis is behaving and performing well will venture off to a new home to work the new master as hard as has I.
Hate to say it but the beatings I gave myself LONG ago have caught up IN SPADES.
tadams(OH)
Yes that has a tendencey to happen to all as we get older.
Sadly so
gemdozer
Orange Level Joined: 17 Sep 2009 Points: 944 |
I think am gone closed soon because have so much arthrite every were legg, arm, back,feet,finger only the head no to bad for my 76 years old.
And the hits just keep coming. Got my crater dug out with the rock laden dirt moved out, need at least three to four decent loads of clean soil back in and garden spot will be good to go then noticed Snail Trails. Fat Allis BICH!! sprung two NEW Leaks while in process. Currently BACK in the shop awaiting my temper to calm.
Hyd Leak on left side Boom or bucket cylinder lines(LESS than three years old) and a drizzle from above the Trans Belly pan.
