Hand sanitizer
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Hand sanitizer
    Posted: 13 Jul 2020 at 8:34pm
FDA says MOST of the hand sanitizer coming from Mexico contains METHANOL instead of ETHANOL.... and the labels are Marked WRONG..
If your sanitizer was packaged in Mexico-- throw it away !!!
These 9 hand sanitizers may be toxic, FDA warns
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:50am
These people are IDIOTS Steve.  Sanitizer can be Ethyl alcohol(Grain distilled) or Methyl(Methanol) alcohol based, gets put ON the hands and evaporates, only toxicity is if try to drink it as the old alcoholics used to drink Mouthwash for the alcohol(Ethyl based).  No different than using rubbing alcohol on the body(Methyl or Methanol)
When they distill drinking alcohol the first stuff and the last stuff off the stills(Heads and Tails) is primarily Methanol based, the sweet stuff we drink is in between the heads and tails!!!  Whiskey companies sell the stuff they cannot use for medicinal purposes(Methanol)
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:05am
Yep.....all except, rubbing alcohol is Isopropyl.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:20am
My wife mixed up a concoction from a recipe she found.  Uses aloe and Everclear (alcohol I bought at the liquor store).  And, no, I don't drink it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:22am
Everclear. . .
I drank it.
Once!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:28am
Solvents absorb easily through your skin and into your blood stream. Some people are real sensitive to stuff and react right off, while others seem indestructible till they drop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 10:58am
good point chas
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 12:14pm
YEA, im not a chemist.. dont play one on TV either... Just pointing out that the FDA says it is not a GOOD idea to spread METHanole on your skin... and i agree, DONT DRINK IT !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 3:10pm
Any and every alcohol is a solvent including those we drink, makes no difference what type is in sanitizer, the issue was mislabeling NOT the alcohol as the drunks could possibly drink the stuff and die.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 3:20pm
Everclear. . .
I drank it.
Once!
Mix it with grape juice concentrate....man you got a good time there! It is, however, not a free ride, you will pay in the morning! Oh the days of my misspent youth!
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 5:59pm
Of course it makes a difference! It also makes a difference in the label for drunks, but methanol is more toxic to your body. So you wouldn’t make a sanitizer that’s toxic and absorbs through the skin. Even if it still kills the virus.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 6:02pm
Originally posted by LouSWPA LouSWPA wrote:
Everclear. . .
I drank it.
Once!
The “Apple Pie” they make has it too. So I guess I’ve had it a couple more times    Yeah it leaves a mark alright!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:21pm
You guys still do not get it.  The Methanol tainted alcohols(Heads and Tails) from Distilleries are NOTED as sold for these type products, unusable anywhere else, can be marketed as Grain Ethyl Alcohol but cannot be used for liquor as does contain methanol.  That can be looked up.
