B wheel lock ???? |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8176 |
Posted: 26 Feb 2020 at 1:34pm |
Hi everyone.
Have some B,IB wheel locks here, both have same part number on it but look different. The part number is 209128 and one measures 3" L,X 1" W, X 1-3/4" H with 5/8" hole. The other is 3-1/4" L, X 1" or 1-1/16" W, X 1-3/4" high with 13/16" hole. Are these the same or should one have a different part number. And a third one with part number of 210215 Didn't take picture of third lock. Thanks Edited by Mikez - 26 Feb 2020 at 1:36pm |
shaun44
Bronze Level Joined: 12 May 2019 Location: pennsylvania Points: 6 |
to be honest i threw those away and bought bolt on rims. i didnt have much luck with those locks and essentric bolts. good luck
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78343 |
I think there might have been a couple supplies for that part to AC and the VENDOR had small variations... but same part for same use ? ............ Clamps work GREAT if they fit correctly.. Old worn out need to be built up with weld and resurfaced.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
Probably the same casting but machined different. If I'm thinking right not all the locks on the wheel accept a cam bolt.
bradley6874
Top one is early b took two of these no eccentric and two with larger hole are for eccentric bolt two of these
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18743 |
The eccentric bolts have a 'cross' in the head of the bolt. I (think) the long leg of the cross went toward the rim, but I'm not sure. I'd have to check one of mine.
Yes, the eccentric piece(s) went on the rim next to each other and the regular locks and bolt next to each other also. Bill will probably remember for sure! |
Mikez
Thanks guys. I wasn't going off casting number for part number. One has masking tape with part number an one has allis sticker tag with number on it. The eccentric bolt will only fit through the one with larger hole. But there's not a different number for one or the other.
Thanks |
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
210215 shoudl be the shraight bolt one, the orange one in pic.
www.awtractor.com
