B wheel lock ????
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=168627
Printed Date: 05 Jun 2024 at 4:11am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: B wheel lock ????
Posted By: Mikez
Subject: B wheel lock ????
Date Posted: 26 Feb 2020 at 1:34pm
Hi everyone. Have some B,IB wheel locks here, both have same part number on it but look different. The part number is 209128 and one measures 3" L,X 1" W, X 1-3/4" H with 5/8" hole. The other is 3-1/4" L, X 1" or 1-1/16" W, X 1-3/4" high with 13/16" hole. Are these the same or should one have a different part number. And a third one with part number of 210215 Didn't take picture of third lock.
Thanks
Posted By: shaun44
Date Posted: 26 Feb 2020 at 1:44pm
to be honest i threw those away and bought bolt on rims. i didnt have much luck with those locks and essentric bolts. good luck
Posted By: steve(ill)
Date Posted: 26 Feb 2020 at 7:37pm
I think there might have been a couple supplies for that part to AC and the VENDOR had small variations... but same part for same use ? ............ Clamps work GREAT if they fit correctly.. Old worn out need to be built up with weld and resurfaced.
------------- Like them all, but love the "B"s.
Posted By: Boss Man
Date Posted: 26 Feb 2020 at 8:16pm
Probably the same casting but machined different. If I'm thinking right not all the locks on the wheel accept a cam bolt.
Posted By: bradley6874
Date Posted: 26 Feb 2020 at 8:50pm
Top one is early b took two of these no eccentric and two with larger hole are for eccentric bolt two of these
------------- You can wash the dirt off the body but you can’t wash the farmer out of the heart and soul
Posted By: Ted J
Date Posted: 26 Feb 2020 at 9:48pm
The eccentric bolts have a 'cross' in the head of the bolt. I (think) the long leg of the cross went toward the rim, but I'm not sure. I'd have to check one of mine. Yes, the eccentric piece(s) went on the rim next to each other and the regular locks and bolt next to each other also. Bill will probably remember for sure!
------------- "Allis-Express" 19?? WC / 1941 C / 1952 CA / 1956 WD45 / 1957 WD45 / 1958 D-17
Posted By: Mikez
Date Posted: 26 Feb 2020 at 10:28pm
Thanks guys. I wasn't going off casting number for part number. One has masking tape with part number an one has allis sticker tag with number on it. The eccentric bolt will only fit through the one with larger hole. But there's not a different number for one or the other. Thanks
Posted By: Alex09(WI)
Date Posted: 27 Feb 2020 at 9:39am
210215 shoudl be the shraight bolt one, the orange one in pic.
------------- www.awtractor.com A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY
