H3/H4/653 Parts available
Spike78653 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Topic: H3/H4/653 Parts available
    Posted: 10 Feb 2020 at 3:22pm
Let me know what you need:
I would like to sell the tracks as a complete set:  They are like new.
Edited by Spike78653 - 10 Feb 2020 at 3:25pm
Spike78653
653
H3
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 3:29pm
are you around Austin Tx?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 3:42pm
Yes I am...
Edited by Spike78653 - 25 Feb 2020 at 6:05pm
Spike78653
653
H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 1:38pm
I also have a complete set of pins and rollers, brand new on the pallet.
Spike78653
653
H3
carolinainn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carolinainn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 1:45pm
I'm new here and I'm looking for info/parts to rebuild a hydraulic track tensioner on a 653. The machine is in Panama, Central America so I have to get it right before I go back there. Thanks.
drmikeg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drmikeg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 5:55pm
You don't happen to have the injection pump off a d2200 available? Looking for the Roosa Master DBGFC 437 -7AG. I'd take any pump to run a d2200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 9:56pm
Sorry the only pump I have is currently on my running 653. But I’ll keep my ears open for anyone that may have one.
Spike78653
653
H3
smokechaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokechaser Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2020 at 6:54pm
Spike, I would be interested in a brake band with lever and adjuster if possible.  Send me a PM. Thanks
A-C HD5G, HD3, I600, WD-45; IH 424, B414, B250, Cub; Oliver OC6; Clark R60; Bungartz T5; Ferguson TO-20; MH 44
jerbob View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 9:00am
This is pretty petty but sure could use the final drive top fill plugs.Both of mine are missing and I have rags stuffed in them right now. Someone ripped them off this past fall while it was parked on my property. I cannot find anything to match up to them.
They appear to be fine thread steel. The opening is roughly 1.5". I have tried numerous plugs only to have them slightly too bid or slightly too small.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 11:58am
Yes I have those.  Send me your address>>
Spike78653
653
H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 11:59am
I will send you a pic of what I have tonight.
Spike78653
653
H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 12:02pm
Fantastic Spike. Thank you.
lflohr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lflohr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 12:27pm
I could use two usable track rollers for my H4
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 6:39pm
I would like to buy the lights.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,(2) 620, 720, ACP25 lift truck, 1956 D Special Grader, AC 540 loader, AC 655 crawler loader, AC #84 plow, Simplicity lawn tractors.
Bsumudd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bsumudd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 10:14pm
Sir,
Do you still have any of the steering components? My 653 does not like to turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spike78653 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 11:00am
At this point everything is sold>>
Spike78653
653
H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bsumudd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2020 at 5:00pm
Bummer. Ok thanks for the reply.
srhays View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srhays Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 9:47am
was wondering if the tracks and sprockets for a HD4 or 653 were available
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 9:55pm
Contact J&H welding for dozer parts
 906 353 6119
 Mike is a nice guy to deal with
superdutympsjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote superdutympsjr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 6:49pm
Looking for H3 Hydraulic pump and or drive shaft!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 1:56pm
The track grousers look as if they came off of a loader and not a dozer. Loader grousers are flat like that to reduce wear and tear on the rollers, sprockets and rear end  because of the frequent turning back and forth with a buckets full of material.
