Allis 190 transmission
Nwest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nwest Quote  Post ReplyReply Direct Link To This Post Topic: Allis 190 transmission
    Posted: 10 Feb 2020 at 12:32pm
Hi again everyone I'm going through an allis 190 gas serial number 7995. I have the tractor split and am in need of several transmission gears. At some point in its life it took a bit of abuse being slammed into gears by the way the gears are worn. There are a couple gears that dont appear to be made anymore. The input shaft number 70245722 being one of them. Does anyone know if its possible to get these parts new? Otherwise the salvage yards I'm sure have some. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 2:41pm
I don't think there's any of the transmission parts available for that tractor. That is the transmission that, if it was a 190XT, everything was replaced with beefier parts, including the shafts. They didn't update any straight 190's, as they didn't feel there would be any problem due to less HP. I'm afraid all you can hope for is used parts from a salvage yard. Be sure they understand it is a 190 tractor PRIOR TO S/N 9001.   Any 190XT has different parts and any 190 after s/n 9001 has the same parts as the XT's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nwest Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 8:16pm
Thanks for the input Dr. Allis. On that note if anyone on this forum has a few early 190 gears I'd be interested or I may be forced to scrap if I have no luck at the yards.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 8:55pm
I have a later rear end assembly from a 190XT gas, I would make a trade with you.
.      MACK
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 12:04am
Just wondering if any gears from a D19 would fit up in there...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:12am
Nope.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 10:01am
PM sent
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 5:28pm
would the complete trans/rear end of a D-19 bolt up to the early 190 torque tube?
Leon B MO
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:15pm
did you check with this Guy?
C.L. ad
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 9:30pm
Housing will bolt up, but input shaft is different.
.      MACK
