I 600 lever by clutch pedal |
black c10
Bronze Level Joined: 02 Feb 2020 Location: Bluehill me Points: 3 |
Posted: 02 Feb 2020 at 7:42pm |
Does my I 600 have diff lock and what does the lever do between shuttle shift and clutch
Orange Level Access Joined: 12 Sep 2009 Points: 20190 |
No diff lock. That's the PTO lever if it is just above the foot clutch pedal ??
black c10
That makes sense bummer no diff lock think I need to adjust shuttle shift comes out of forward when it’s cold or in higher rpm thanks for info pto lever was really baffling me hoped it was diff lock not a lot of info on this old girl
The only adjustment on the shuttle clutch for that problem is this: there is a 3/8" stop bolt that the lever comes up against when fully forward. Remove some flat washers from under the head of the bolt or just remove the bolt itself. The jumping out with cold oil is because the internal latching mechanism is getting worn out. They are only good for so many thousands of times being latched and unlatched, and eventually wear. Don't let anyone tell you the clutch needs to be "shimmed". That will only make it worse and shows they don't know what they are talking about.
