200 pto problem
royce vallejo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote royce vallejo Quote  Post ReplyReply Direct Link To This Post Topic: 200 pto problem
    Posted: 24 Jan 2020 at 11:04pm
I have a 200 with a pto problem. It slips  on  my  425 new Holland baler. I replaced the driven  and driving plates. it has the  540 and 1000 rpm pto speed. any ideas why it can't even turn a 1012 new Holland bale wagon
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 12:30am
Mine did the same thing. It was a hyd valve problem. I do not remember where or what it took to fix it. It's been 5 0r 6 years ago.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 7:52am
Sounds like pressure needs to be checked.      MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 8:50am
IF you idle the tractor to 1000 rpm , put it in high range 4th gear and slowly let out the foot clutch - does the PD clutch slip as well ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote royce vallejo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 10:08pm
I replaced the main cluch during that time. This is  my first ac 200. I am going to have to figure out where the pd cluch is. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote royce vallejo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 10:22pm
I have not tested the pressure but the three point and  the bucket goes up and down no problem. I will test the pressure. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote royce vallejo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 10:27pm
thanks for the info on a possible hyd valve prob.
