AC B tractor
Guadamo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guadamo Quote  Post ReplyReply Direct Link To This Post Topic: AC B tractor
    Posted: 05 Jan 2020 at 10:59am
I have a AC B tractor that I bought from my neighbor about 12 or so yrs ago that has spoke wheels on the front wheels , the tractor has serial number 2876 , I have seen several b Allis chalmers but have never seen another like mine can anyone give me some info on the spoke type wheels.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 12:37pm
Probably came with steel wheels. They cut the outer wheel off and welded a regular rim to it to convert to rubber. A pic would be help full
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 2:31pm
This was also done with some WWII steel wheeled tractors.  Frankly, after WWII we usually junked the steel wheels and replaced them with rubber tired wheels and rims.  Whoever did this apparently did a good welding job.
Take good care of my favorite.
I too would like to see a picture.
Good Luck!
Bill Long
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 3:43pm
I have two steeled wheel B's (one has been parted out) that both have the spoke wheels with rubber tires. The "experts" on here tell me they were never made by AC, but I find it odd that I have two with exactly the same wheels. If they were conversions, whoever did the conversion was a real good welder !
I will try to find some pictures to post.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 3:55pm
Look real close where the spokes are attached to the rim, you should easily tell if they were welded on to rim after the steel rim was cut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guadamo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:55pm
I kinda think that is the case the wheels look like they are welded to a rim , in fact one of the rims rusted thru and I got a friend that is said he would fix them for me if I buy some new rings/rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 8:09pm
Allis didn't make the round spoke wheels. They were a purchased finished part and had a steel wheel. The spokes were riveted into the steel wheels from the manufacturer, with no welding involved. It's real easy to see that a rubber tire rim is welded on to the spokes.
 In this picture you can see how the spokes are swedged in place.
 Image result for Allis B steel wheels
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 8:29pm
Are you sure rubber tires weren't a choice with these rims? I have four of them that look exactly like the one in the photo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 8:44pm
 I would bet my paycheck, that your spokes are welded to the rubber tired rims. That never happened in production.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guadamo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 9:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guadamo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 9:59am
I'll try to get a close up later of the rims....thanks to all
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 10:08am
On page 55 of the "Bible" (Norm Swinford's Book) there is a picture of a war model B with steel wheels with this caption:
"Although the Model B was specifically designed for rubber tires, this 1942 model did not get an exemption from serving on steel wheels in World War II.
As soon as ties becamed available, most war tractors had their wheels cut down and rims welded on."
So.....I guess it would be fairly common to see wheels welded up as seen in CTucker's picture.
This page was generated in 0.238 seconds.
