Print Page | Close Window
AC B tractor
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=167135
Printed Date: 28 Oct 2025 at 7:29pm
Topic: AC B tractor
Posted By: Guadamo
Subject: AC B tractor
Date Posted: 05 Jan 2020 at 10:59am
I have a AC B tractor that I bought from my neighbor about 12 or so yrs ago that has spoke wheels on the front wheels , the tractor has serial number 2876 , I have seen several b Allis chalmers but have never seen another like mine can anyone give me some info on the spoke type wheels.
Posted By: Boss Man
Date Posted: 05 Jan 2020 at 12:37pm
Probably came with steel wheels. They cut the outer wheel off and welded a regular rim to it to convert to rubber. A pic would be help full
Posted By: Bill Long
Date Posted: 05 Jan 2020 at 2:31pm
This was also done with some WWII steel wheeled tractors.  Frankly, after WWII we usually junked the steel wheels and replaced them with rubber tired wheels and rims.  Whoever did this apparently did a good welding job.
Take good care of my favorite.
I too would like to see a picture.
Good Luck!
Bill Long
Posted By: WF owner
Date Posted: 05 Jan 2020 at 3:43pm
I have two steeled wheel B's (one has been parted out) that both have the spoke wheels with rubber tires. The "experts" on here tell me they were never made by AC, but I find it odd that I have two with exactly the same wheels. If they were conversions, whoever did the conversion was a real good welder !
I will try to find some pictures to post.
Posted By: B26240
Date Posted: 05 Jan 2020 at 3:55pm
Look real close where the spokes are attached to the rim, you should easily tell if they were welded on to rim after the steel rim was cut off.
Posted By: Guadamo
Date Posted: 05 Jan 2020 at 5:55pm
I kinda think that is the case the wheels look like they are welded to a rim , in fact one of the rims rusted thru and I got a friend that is said he would fix them for me if I buy some new rings/rims
Posted By: CTuckerNWIL
Date Posted: 05 Jan 2020 at 8:09pm
Allis didn't make the round spoke wheels. They were a purchased finished part and had a steel wheel. The spokes were riveted into the steel wheels from the manufacturer, with no welding involved. It's real easy to see that a rubber tire rim is welded on to the spokes.
 In this picture you can see how the spokes are swedged in place.
 Image result for Allis B steel wheels
Posted By: WF owner
Date Posted: 05 Jan 2020 at 8:29pm
Are you sure rubber tires weren't a choice with these rims? I have four of them that look exactly like the one in the photo.
Date Posted: 05 Jan 2020 at 8:44pm
 I would bet my paycheck, that your spokes are welded to the rubber tired rims. That never happened in production.
Posted By: Guadamo
Date Posted: 06 Jan 2020 at 9:57am
Posted By: Guadamo
Date Posted: 06 Jan 2020 at 9:59am
I'll try to get a close up later of the rims....thanks to all
Posted By: Brian G. NY
Date Posted: 06 Jan 2020 at 10:08am
On page 55 of the "Bible" (Norm Swinford's Book) there is a picture of a war model B with steel wheels with this caption:
"Although the Model B was specifically designed for rubber tires, this 1942 model did not get an exemption from serving on steel wheels in World War II.
As soon as ties becamed available, most war tractors had their wheels cut down and rims welded on."
So.....I guess it would be fairly common to see wheels welded up as seen in CTucker's picture.
