difference between 190xt- 200 |
ribsplitter
Topic: difference between 190xt- 200Posted: 22 Sep 2010 at 6:31pm |
what are the differences between a 190 xt and a 200?
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 22 Sep 2010 at 8:17pm |
Later 190xt had wider finals than earlier and 4 pinion differential but most XT diesels were changed over on a recall to wider finals. The 200 had even wider finals. The 200 had a MarkII? 2900 engine with a better cooling fan and other improvements. Grill is different. Some other minor changes in hydraulics. Fuel gage is in the tank and not on the dash at least on some anyway. Not a whole lot of differences really.
Wink I am a Russian Bot |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 22 Sep 2010 at 9:13pm |
200 was first to have factory AC cab, 190 XT cabs were aftermarket
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 22 Sep 2010 at 9:17pm |
I believe the 200 had different 3 point geometry and could lift about 50% more?...also thought I've seen some comments about the 200 having a "gated" power director lever on the side console that caused some PD wear problems if not adjusted correctly. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 22 Sep 2010 at 9:18pm |
200 Had a different turbo and resonator, and a slower turning blade fan for better cooling. To name a few. Right from Norm's boodk.
DSeries4
7 blade fan
Lester
Posted: 23 Sep 2010 at 6:23am |
The 200 also had 2 oil filters .
gcalent
Joined: 19 May 2010 Location: Willards, Md Points: 179 |
Posted: 23 Sep 2010 at 8:55am |
later 200`s had the better disc type brakes that held better and lasted longer
Pullin With AC
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10413 |
Posted: 23 Sep 2010 at 9:00am |
The 200 is ten more than the 190.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1220 |
The 3pt had the cylinders mounted below the axle line on the axle housings versus above, giving better geometry. 7000 was the same way. Also, didn't the 200 have wider gears in the transmission?
Hurst
1979 Allis Chalmers 7000
5800 Hours |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 23 Sep 2010 at 10:12am |
the 200 had larger axles, also offered long axles. the gated power director was part of the cost reduced tractors I think, as early ones had the same lever as a 190. the 200 should actually dyno about 105hp also since they were never tested, and based on the XT test. the injection pump for a 200 is set for higher fuel delivery than an XT, although later XT's were set to a higher spec than the early tractors, the 200 is still a little hotter.
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 615 |
Posted: 23 Sep 2010 at 10:30am |
Axles are the same diameter from later 190 to 7000, 3 1/4 inch. |
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 23 Sep 2010 at 8:43pm |
Did any xt's come out with the hyd. pto clutch.
Leon B MO
AllisChalmers37
Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
Posted: 23 Sep 2010 at 8:51pm |
Is it just me or does that cab on the 200 look somewhat like the one on a 7000 series?
![]() VS
![]() Edited by AllisChalmers37 - 23 Sep 2010 at 8:51pm |
injpumpEd
Posted: 23 Sep 2010 at 9:11pm |
yes, the cabs do seem similar. the side windows are drilled with bolts going through the glass to attach to the metal hinge. definitely a family connection.
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 23 Sep 2010 at 9:18pm |
Didn't the 200 come with 38" rubber as standard whereas the standard for the 190 was 34"? Also didn't the 200 have the two speed pto option where the 190 was either/or?
ALLIS EXPRESS!
This year: |
Lonn
Posted: 24 Sep 2010 at 5:30am |
Late 190's had the optional dual speed PTO.
Lonn
Posted: 24 Sep 2010 at 5:31am |
Yes, from the beginning it was an option. My Dad's gas XT is a 1965 with this option.
Lonn
Posted: 24 Sep 2010 at 5:33am |
Both Cabs are designed and built by Allis.
Lester
Posted: 24 Sep 2010 at 6:25am |
A very low % of 200s came with 38s.
