Truck tire rotation |
Page 12> |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Sep 2019 at 6:46am |
Did mine a couple days ago . Owners manual says not to put any oil/grease on studs . I put 2 drops of oil on each stud . Then torqued in sequence to 140 lbs . Wondering how you fellas do it ? Thanks
nella(Pa) ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3124 |
Everything gets antiseize that might rust.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8365 |
I always use WD 40 or some kinda lube,, once they hit 140 lbs they are on there good, Don't think I'd put antizeze on wheel studs,, but just my opinion
Edited by DougG - 29 Sep 2019 at 7:04am |
I put it on cars, trucks ,tractors, wagons for many years and never had a problem. Just did the lawnmower, before anti seize I used grease on the threads. About 65 yrs. worth of experience.
Edited by nella(Pa) - 29 Sep 2019 at 7:25am |
We don't have road salt to deal with down south . I just don't like the idea of dry threads . Thanks
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
anti-sieze on wheel studs for 50 years, never had one problem. IF you put anitsieze on the drive pulleys of rider you CAN get them off 22 yeras later instead of cutting/grinding off $80 pulleys ! I also rotate tires in teh std X pattern contray to what 'they' say as it evens out wear.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
I don't rotate my tires. I figure that if I did then I would have to buy a complete set of tires at once. I'd rather buy tires in pairs.
Dusty
I just get in and drive . . . and that rotates the tires!
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
If you don't rotate your tires you could get stuck in traffic!
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Dusty, on the newer AWD vehicles, if you ruin one tire that is worn much they will not sell you one, have to buy all four. They claim it will ruin the transfer case, went to 2 different tire stores and same thing, had to put all 4 new. Just my experience.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
anti-seize here for 55 years!---NEVER lost one yet! ---- As far as rotate,---I don't! -- No need to IF your front end is kept in good shape.
Edited by ac fleet - 29 Sep 2019 at 9:15am |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8652 |
I think what the smart people believe(rule makers) is that lubed studs will let nuts work loose.Not so much dry. Torque figures are for DRY threads so if lubed you may want to adjust a little. Think they reason that lubed threads lead to over torque an possible breaking studs. All valid points but they have never dealt with large truck wheels which have lived on gov't treated winter highways. No antisieze and you'll need a torch. An impact wrench in the wrong hands is not a good thing. Forty years with antisieze and no failures.
Makes sense that the torque number is for dry threads . Two reasons I rotated my tires myself . One , to get a few more miles out of them . Two , I had to use a 4' cheater to loosen the lugs after it left the tire shop . Thanks
Edited by ACinSC - 03 Oct 2019 at 12:47pm |
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
Tire shops don't believe in torque wrenches.
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
We usually work on Ford trucks and Ford has a lug nut with a washer made to it. If they don’t move like they should I spray them with WD-40 or PB Blaster. We will put anti seize on the hub where the brake rotors ride because we have to beat those off with a hammer. And we always torque the lug nuts. I agree with dry threads but when you have rusted studs or corroded lug nuts I think it needs a little lube to be torqued correctly. As far as rotating tires here in NC with our curvy roads the front tires will round the edges and the rears will stay square shouldered so that’s why I rotate tires although I don’t do it religiously like every 5000 miles it usually more like once or twice the lifetime of the tires.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88273 |
Red Bank....... im in 100%... but I put a drop of anti sieze on the studs too...
Dunno if the tire shop manager lied or just didn't know what he was talking about because I questioned him about overtorquing the lugs . Had a nail in the tire and that's when I had to break out the cheater bar . Just glad I was home . Thanks
It's not thread friction that keeps them tight anyway, it's clamping force, and there is about as many opinions about this as there is hair on a dogs butt.
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
Boys I owned a tire shop for 22 plus years. Along with that I had a service truck. I have been out along the road many times all hours of the day rescuing people who lubed up lug nuts. The cops and highway patrol all had my phone number. If people couldn't afford a tow truck, they called me. We always torqued wheels. We kept 3-5 torque wrenches at all times. Every 3 months at least 2 were sent away for calibration. Then one of our tool men came up with access to a torque wrench calibration place. He'd take them in for us and have them back the following week. We never lubed or antisezed a wheel.
I have used anti sieze for 50 years on the center hole and the studs. Never used a torque wrench, do them by hand... I got a pretty good feel for TIGHT... Never have had a problem.
Thanks for all the replies . Guess I will shop around before I buy tires and see if anyone uses a torque wrench . I'll probably keep putting a couple drops of oil on the studs but back off the setting a smidge . Thanks again
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12232 |
![]() ![]() ![]() I have split the socket open on the tire iron that came with the truck, have rendered another tire iron useless / bent on a different vehicle, have broken a SK socket, have sheared a 6 inch extension, and have blown the head apart of a breaker bar, and of course those anti theft lugs really hold up to 4000 ft lbs, trying to take off tires after a visit to the tire store ![]() ![]() ![]() Where I used to live, stopped in a tire store one time where they had a big window behind the counter where you could see out into the service area, and lo and behold, there was a guy using a torque wrench!!! I mentioned it to the counter guy, yep we use torque wrenches all the time. Over torqueing is bad for brake discs, bad for aluminum wheels, etc. Well, yes, I know that, but seems nobody does that. I said, you guys have my business for as long as I live here! About 2 years later, I stopped in for some tires, heard the unmistakable sound of impact wrenches. What, no more torque wrenches? Guy just looked at me funny. New Management!!! ![]() ![]() ![]() After any trip to any tire store or service where the wheels come off, I drive into my driveway, loosen all of the lugs, and tighten them with a torque wrench. That way, I know when me or worse yet the wife or daughter, get a flat in the rain at night, the tire can be changed as intended, where I don't have all the tools to use with me as I would at the farm. Huge pet peeve of mine!!!!!!!!!
Edited by Tbone95 - 30 Sep 2019 at 8:42am |
Kinda think part of the problem is very few guys change their own flat tires anymore . Just call for help . JMHO. Thanks
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
I just had new tires put on my truck. They said come back after 150 mi to have the lug nuts retorqued. Took it back and the tire guy went all around with a torque wrench.
mdm, all I can say is that's way too LATE. More than one occasion I know of, one my dad, where wheels come off. That too is a result of being hasty with an impact wrench, where the wheel is not really seated flat against the hub, and you have no feel with the air wrench, so what felt like it tightened up was really just a bind and going down the road things change in a hurry. Dad's back tire passed him as he was slowing down to turn down our road. Had it been a front tire, likely would have been an accident losing control.
DonBC ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 946 |
I nearly lost a front wheel on my small pickup when I replaced the wheel after a flat repair. I was in a rush and only used the impact. Luckily I became aware of a slight sound when going around a curve on a street near home . I checked the wheel nuts as soon as I got home and found that they had all loosened a little. Learned my lesson and used the torque wrench. My daughter and SIL lost a front wheel when all the studs broke off while on a road trip. A mechanic that repaired their van checked the other wheels and found that they were all excessively torqued. They had had tire work done by a well known tire franchise the week before. The tire shop accepted full responsibility and paid for all their cost, towing, mechanic, hotel, meals, etc.
I have only used WD-40 when taking nuts off of long studs that dirty or corroded. WD-40 is only a short term lubricant that seems to evaporate in a day or two. My usual tire shop wants us to come back for a torque after 200km (125 miles).
One 'trick' I used when I had real 4WD rides( CJ-5, Willys..), was to put 2 drops of oil into the 'solid, one piece' chrome wheel nuts. The ones that cover the studs. I never, ever had a problem getting them off or on. Nut covers 100% of the stud, oil stays in there for months if not years.
This dose happen, I seen a truck tractor that lost a tire on the road and caused a bad accident because of being over torqued. Then they put an air regulator in the line to control the torque.
Single mother and her daughter that played travel softball with my daughter, had new tires put on her vehicle before heading out of town for our tournament. Had about a 140 mile drive. Sitting in the stands, overheard the talk about a strange noise her vehicle was making. Everyone was blowing her off, one mumbo jumbo excuse after another, so I said, this noise happened part way down here, was fine before? Yep.
So after the game I drove the vehicle, slow, windows down, yep, there's a noise. Checked the lugs, virtually every lug was somewhat loose. Driver's rear was really bad, whole wheel would wiggle up on jacks, and I easily broke one of those studs, and broke another on the other side. Got everything snugged up, but I was nervous for her. Told her to take her time and keep her ears open on the way home, and she made it safely. It was a Sunday afternoon wouldn't you know. Next tournament, well.....she bought my family dinner, even though I insisted nothing was necessary!
Edited by Tbone95 - 01 Oct 2019 at 7:00am |
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2253 |
My '03 Dodge dually manual says to put a drop or two of oil between the nut and the flange washer that's permanently attached to it, so that when you tighten it down it's spinning on that interface instead of against the axle hub once it starts to seat. Otherwise, threads on the studs and nuts stay dry for the reasons mentioned above. I wire brush them or similar to clean them out if dirty.
Page 12> |
