My A-C lineup today
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: My A-C lineup today
    Posted: 21 Sep 2019 at 8:51pm
It was the gathering of the D17's outside my repair shop today so I thought I'd snap a couple pictures. Top D17 is late series I, did a clutch job and replaced some small parts, waiting for the customer to pick it up. The guy uses it to haul hay wagons and rake hay.
The 2nd D17 is a mid series I. I repaired the power director, and fixed some oil leaks, just finished the tractor this morning. Guy uses the tractor for food plots, plowing snow.
The 3rd D17 is a late series III. Its scheduled in after the 200, needs some oil leaks fixed, different muffler and has way too much free play in the rear end or differential that needs to be fixed. The customer uses the tractor on his small hobby farm along with other Allis's and a 4020.
The G is scheduled after the D17. Needs a rusted clutch fixed.
The 200 will go into the shop tomorrow to get the rear end swapped with a good rear end, needs bushings in the power director linkage, and the injectors checked out. Guy uses this on a small 40 cow dairy farm with another 200, 185, 6080, 8010 and newer JD loader tractor. Mostly used on the spreader in winter.
www.awtractor.com
A&W TRACTOR 920-598-1287
Mosin9130 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mosin9130 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 9:11pm
Great looking lineup
'56 WD 45...'63 D15 II...'66 D17 IV
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:44am
Alex that is a nice bunch of 17 s wish that the series III were mine. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 7:11am
Thanks for posting pics. Good job keeping them up and running
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 7:50am
Alex, what do you think about the aftermarket wide front on the  D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 7:38pm
That one is a Norden. The center steering arm has to be modified for the wide front to work. Steers just as easy as the Allis wide front, but the tractor has power steering. It is harder to do maintenance on the steering gearbox with the Norden vs the factory wide front. The mounting angle brackets interfere with some bolts. I didn't get to check if the turning radius is the same, but I would guess its not as tight. Overall, I can't see any advantage to the Norden over the A-C wide front
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 8:50pm
These old tractors and dedicated customers are keeping you busy! Thanks for the pictures!
