#2 diesel vs #2 furnace heating oil? |
Page 12> |
Author | |||
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jun 2019 at 12:29pm |
Thinking about using heating oil instead of the biodiesel because there is no requirement for #2 heating oil to be blended with biofuel. Pro's..... con's?
Wink I am a Russian Bot |
Sponsored Links | |||
Mike Plotner ![]() Orange Level ![]() ![]() Joined: 02 Apr 2014 Location: Central Ohio Points: 1577 |
Burn bio diesel. Create demand
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Edit..... I think I just got your joke ![]() Edited by Lonn - 15 Jun 2019 at 1:37pm |
I don't get guys that moan about low soybean/corn prices and complain about using bio-diesel/Ethonal.
I'd rather payless to run a tractor while also using up our product |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29909 |
House will smell like a French fry factory, all the neighbors will get the munchies!!
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 758 |
I agree.
Tim NH ![]() Orange Level Access ![]() Joined: 16 Oct 2012 Location: Lancaster NH Points: 1066 |
I was told by oil delivery man, that diesel fuel is refined a little more than #2 heating oil.
Tim
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
Don't think the heating oil has the additives to protect your pump and injectors from damage
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8072 |
Bio is fine while using it. That's all I burn in the road tractor(partly because that's all I can buy on the road). It's not worth a crap to set for 6 months in a tractor fuel sysem from the old days. Maybe Mike is running modern electric engines. I pay extra for non bio on the farm. Maybe it's not extra at all in the end.
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1172 |
Lon, I owned a farm fuel business for years. There is a great difference between #2 diesel and fuel oil. You should be using a premium #2 diesel in everything on the farm. Premium #2 diesel has a higher cetain rating than #2 fuel oil. #2 fuel oil has less additives than #2 truck stop fuel. There is no anti algecide in #2 fuel oil or #2 truck stop diesel. There are no lubricating additives in #2 fuel oil, something you need for today's close tolerances in pumps and injectors. If you decide to use #2 fuel oil you will see more black smoke going up the pipe. Black smoke is unburned fuel.
Edited by 200Tom1 - 15 Jun 2019 at 8:11pm |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4471 |
Back when I was hauling fuel from the tank farms to delivery points, the Diesel fuel, heating oil and off road diesel were loaded from the same pipe. If it was premium diesel The metering system would inject an additive at the correct rate. For non taxable use (heating oil or off road diesel) the system would inject RED dye. That is the only difference for full petroleum fuel oils. Any Bio diesel blends were either tank blended or sometimes the system would do it.
wade89 ![]() Bronze Level ![]() Joined: 12 Feb 2018 Location: Northern MN Points: 194 |
I know the bio diesel left alot of scummy crap in the bottom of a D17D tank and Dads 922b cat loader. I would only run heating oil in the old equipment.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
I never had such algae problems in my life as when I was running bio diesel in my remote generators. I had to switch to what the dealer called "stove oil" in order to get a fuel that didn't contain any bio products. In a nutshell: No problems at all were encountered after making the switch. None in the five years I witnessed after making the switch. I'll have to ask if they've encountered any problems the next time I call my old workplace for my usual updates.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4445 |
I never heard of "truck stop fuel" before. I thought fuel from truck stops was premium diesel. Has anyone else heard of truck stop fuel ?
I haven't
Play Farmer ![]() Orange Level ![]() Joined: 13 Jan 2016 Location: NNY Points: 732 |
When we buy fuel oil for our house the ticket says "#2 Diesel fuel delivered as #2 Heating oil".
I'd say in our case they're the same. |
“Truck stop fuel” is generic lowest cost fuel, without any additives of any kind. Many truck stops have this and also have a dedicated pump for premium diesel. Back when fuel was less than $1 a gallon, I found the 2-3 cents a gallon extra that Southern States charged at the time for their premium diesel, restulted in increased fuel miles that saved money overall. |
No one should be forced to run anything, but I'm willing to bet you'd complain about the cost of straight petroleum diesel.
And they guys saying I run new engines, I don't, I have a 7060, 7000, One-Ninety, 4620 and a R42. Changing filters every year and maybe adding some additive is still cheaper than buying non biodiesel firbthe amount of gallons I burn all year. Plus, I even run ethonal occasionally in my '82 F-350 and '83 LTD, along with my gas tractors
You're forced to because we're trying to "save the environment". It doesn't matter there is basically a zero net gain on emissions, and a negative net by some studies, the greenies feel better. With that said, its June 15th, it was in the 40s last night, the furnace is currently running and we've been running about 15-20 degrees below normal. If this is the effect of curing "Global warming" (money grabbing hoax) I think we've gone far enough. Let's bring back some warming soon please! ![]() Might be time to move this one to the Politics section. ![]() Edited by Play Farmer - 16 Jun 2019 at 10:48am |
I don't care about emissions, I'd like to have a use for the millions of tons of soybeans we grow every year.
My fuel supplier adds algecide to the blend to prevent it. I also put many hours on my tractors without issues directly from biodiesel use |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78550 |
I think a lot depends on your location, supplier, addatives, and humidity/ weather for YOUR FUEL............ I have been running Ethanol in EVERYTHING for 30 years and never ONE PROBLEM... don't know why.... others have had problems........ but its a fact for me.
exSW ![]() Orange Level ![]() Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
It has a lot to do with the fuel distribution network. I've had nothing but issues with ethanol. Plus the biggest retailer around here has a stranglehold on non ethanol "rec" gas and breaks it off in us. You have to buy bulk from the distributor and that's nit practical for a handful of small gas engines.
If all bio diesel was made from soybeans I might consider it.But it's not and there's where the trouble starts. Glad Mike can get soy based bio.
I've been running bio in my D17D since I got it. All bio diesel you buy is not created equal though. I only get my tractor fuel from Heartland Co Op. Their bio is only blended with soy oil. The same with Key Co Op here in central Iowa. Elsewhere like convenience stores and truck stops there's no telling what it is. Bio made with animal fat is poor quality in my experience and nearly impossible to keep from gelling in cold weather. I can say if you have either a Heartland or a Key co op, they are good quality fuel. The city of Newton IA Fire and Rescue dept buys their fuel at Key.
ebowman ![]() Bronze Level ![]() Joined: 06 Sep 2018 Location: Kirklin, IN Points: 161 |
I believe we have seen the end in sight.....
We change corn so its not fit to be edible by humans and livestock, We are more worried about our gas tanks than our bellies, The farmer only cares about his wallet, The farmer is still "poor", But in reality...... The government will bail him out when he can't pay his bills or has a bad year, And he still gets a brand new pickup truck every couple years!!! Roundup is the greatest thing since sliced bread ( not harmful) until.... a foreign company buys them out and now IT WILL KILL YOU!! I only buy ethanol free gas, if I could buy non bio fuel I would!!
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
WNYBill ![]() Silver Level ![]() Joined: 04 Jun 2016 Location: WNY Points: 276 |
The "Greens" are winning. Here in NYS home heating oil is more expensive than over the road diesel in Ohio or anyplace further south. The Greenies don't care, most don't know where it comes from or what it is!!!!!!
Keep on electing Progressive damn fools! Just look at the cities and states controled by the Democrats. The progressive democrats want to control us all and they are winning. WAKE UP AMERICA
I see New York is mandating some crazy amount of biofuel IN YOUR HEATING OIL Bill. In like 15 years it will be......... can't remember..... 35%? Good luck with that. Right now in MN from April 14 through September 30 20% bio is required in diesel fuel....... I think they any ag based product except palm oil. For some reason palm oil doesn't count. I'm pretty sure ethanol is mandated to be corn based only and I think that is 15% now. So I looked up the law..... if biofuel is so trouble free then why does the law have Generators in Nuke plants as exempt from using any biofuels. "motors located at an electric generating plant regulated by the Nuclear Regulatory Commission" exempt. Also exempt in Minnesota..... the Coast Guard and yes because of Lake Superior Minnesota does have Coast Guard ships on it's shores. Hmmmmmm why are they exempt? Do tell, batman. They must really hate farmers. |
Joe(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 966 |
I farm and raise corn and soybeans. But I don't understand why that means that we should support inferior fuel. If we need to burn our crop to increase prices maybe the American farmer, myself included, needs to learn to diversify our crop production. Saying that we need to create bio diesel from soybeans to create a demand because of over production just doesn't make sense to me. "This is an easy one, economically. Biodiesel is very expensive, relative to petroleum diesel," says Scott Irwin, an economist at the University of Illinois, who follows biofuel markets closely. He calculates that the extra cost for biodiesel comes to about $1.80 per gallon right now, meaning that the biofuel law is costing Americans about $5.4 billion a year.
http://www.npr.org/sections/thesalt/2018/01/16/577649838/turning-soybeans-into-diesel-fuel-is-costing-us-billions
As far as ethanol gas goes I have not had a good experience with ethanol. If ethanol is so great why isn't it used in aviation? And to top it off ethanol is not cost effect to create without the government propping it up. http://www.organicconsumers.org/scientific/70-percent-more-energy-required-make-ethanol-actually-ethanol-cornell |
Page 12> |
