problems continue
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Topic: problems continue
    Posted: 12 Sep 2010 at 9:56am
We replaced the engine in our f2 with a used motor the new motor runs fine we drove it home from the dealership about 2 hrs and notice fluid coming out of the injector port or hole. Don't know if it is fuel or motor oil mechanic thinks that it is motor oil and suggestion as to problem
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 7:17pm
If it's motor oil, it's a leaking valve cover gasket. If it's fuel, it's a leaking injector body down inside the injector bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 7:24pm
Dr. Allis what ever is leaking is coming from the injector bore
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 9:22pm
It most times is a leaky valve cover gasket.  It could also be the injector as Dr says.  I have thought that I had a loose fitting on the injector before but the valve cover gasket was leaking just behind and beside (two different tractors and a combine engine) the injector.  Probably didn't show up until it was warmed up and I am sure whomever sold you the engine had washed it up clean for you.  Try to tighten the valve cover hold down bolts.  I have had them come loose and then leak.  Sometimes tightening them up will stop it till they vibrate loose again.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 9:30pm
More often than not this is a valve cover gasket which runs into the injector hole then on out.Check it out.
