8070 volt light
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8070 volt light
    Posted: 08 Sep 2010 at 4:32pm
i put a new alt. and the volt light still comes on even at high idle, old alt checked out bad. is there a connection or a relay some where i need to check? new batteries and good cables. i bought this tractor with a bad engine and someone else took it apart and i rebuilt the motor, so i have no history about it. thanks randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 5:03pm
Where did you get the replacement alt? My experience in the past with places like O'Reilly and Auto Zone is you will go through 3 or 4 before you find a good one. I would have the replacement tested. Make sure that the main post on the back of it has battery voltage. If it is a Delco 10SI, there should be battery voltage at both terminals on the connector with the ign sw on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 5:35am
new alt ,i saw it tested on the bench, and yes there is power to the one post on the alt. it is a one wire alt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 6:32am
Verify whether the alt is charging (or not) by placing an ammeter in-between the hot connection at the alt and the feed wire. It may be charging and your dashboard could be the problem by not turning off the light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:24pm
does the light panel on the dash control the volt light? will try the amp meter tomorrow, THANKS for help!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 9:41pm
Put a volt meter across the batteries. Should see 13.5 to 14V if it's working. I agree with the Doc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 7:11am
finally fixed the alt, after 3 different regulators, this one is a self exciteing that starts at a lower speed and i believe it works off the stator. anyway a delco needs a special reg to work with this tractor. thanks for all the help, also sent old neihoff to be checked out, but new delco was still cheaper than a reg alone from neihoff.
