D17 IV overhaul kit |
Craig from IL ![]() Bronze Level ![]() Joined: 08 Aug 2010 Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2010 at 8:21pm |
What's the best overhaul kit for a D17 IV gas? Craig
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20976 |
An AGCO "170" motor kit.
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1698 |
i can get the 170 kit complete for 650$
An AGCO kit is 4 inch bore and 8.0 to 1 compression ratio....all after market 4 1/8" bore are less compression.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9504 |
An AGCO kit for $650 would be a no brainer.
D17brown, where or who do I contact? Thanks! Craig
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 518 |
I would rather have the D-17 overbore than a little higher compression. A D-17 with an overbore puts more power than a stock 170.
Call Bill, Brenda, or Betty at Sandy Lake Imp. I would go with the 170 kit. The aftermarket over bore kits give a WD45 compression ratio so I'm told.
Some facts.....a 170 would actually produce about 4 to 5 more HP if you removed the live hydraulic pump and installed an old D17 belly pump. The D17 IV was never Nebraska tested and in reality would only produce about 48 or 49 HP compared to an old 1957 D17 that was tested at 53 HP. M&W made an overbore 4 1/8" (no longer available kit SP48) that was 7.5 to 1 compression( made 57 HP) vs a std D17 that was 7.25 to 1 compression and 4 inch bore (53 hp). You will not be disappointed with a 170 kit in a D17.....you will be disappointed with any aftermarket overbore kit if it isn't at least the same compression (7.25 to 1) as a D17 and I don't think there are ANY out there that are. I believe them to be 6.5 to 1 or thereabouts.
Thanks for all the input guys! Craig
craig, my number is 5635420673
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
I remember having this discussion some years ago. I'd go with the 170 kit. The higher compression will get you more than the 1/8" overbore but I couldn't convince a few here back then.
Wink I am a Russian Bot |
And more economical/fuel efficient than an overbore/lower compression kit.
Jon(OH) ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: New Phila.Ohio Points: 48 |
Could this kit be used in a wd-45 ?
Clay Bragg ![]() Bronze Level ![]() Joined: 15 Sep 2009 Points: 16 |
dont you also need 170 camshaft for best results?
Kit could be used in a WD45 ( won't be able to start it without 12 volts and will stress the crankshaft for hard farming use) and a 170 camshaft grind is the SAME as a D17.....175 cam had a different grind for more valve lift.
CJohnS MI ![]() Orange Level ![]() Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
Well how much higher does it put the comp ration on a WD 45 then? Meaning, is it well beyond 87-93 octane will do to prevent knocking? |
Compression ratio on WD45 is 6.5 to 1..........D17 is 7.25 to 1......170 is 8.0 to 1......all run on regular gas and the D17 and 170 are timed at 25 degrees BTDC at full throttle where the WD45 is 30 degrees BTDC. I'd run 89 octane if it was mine, but no need for any better than that.
The specs say the Gleaner E engine with Z code had 8.1 comp ratio.
But if I read between the lines correctly, the easiest way to get max HP using stock AC parts - is to drop a 175 gas engine into a WD 45. Sound about right? |
Yes....good luck finding one.
LOL! Appreciate that fact. Thanks for the info. This thread has been very informative. |
I put a 175 kit (8.25:1) in brother's D17 back about a dozen years ago. Worked great. At D17 rpm of 1650 it dynoed at 56 HP before a complete break in period. Never had it on a dyno since cause he after a year or so dropped in a hopped up E engine to satisfy his pulling fever. Thing is after he did that he never pulled it for lack of time but before with the 175 kit he trophied all the time. That was a fun project, we just made our own jig to weld H Farmall top half of connecting rods to the bottom end of the D17 connecting rods. Made the jig by eyeball work only. Then attached Chevy 350 4" bore pistons to them. Compression was so high that on pump gas when you'd shut off the key switch it would make no difference as the engine would run and sound like it did with the switch on. Brother then got nervous and pulled the coil wire which did nothing. Had to shut off the gas. Bought airplane fuel and that did the trick. That thing really cackled loud with the 3" straight pipe he put on. Only cost were a gasket kit, used connecting rods and new 350 pistons. We just reused the old bearing as they looked good. Still has the engine on the shelf and we just talked about dropping it in a WD and to actually see how long it holds together if we go pulling it. OK I veered of a little.
Edited by Lonn - 08 Sep 2010 at 7:31am |
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Are the 175 and the 170 the same compression ratio?
Almost...8 to 1 on all 170's and 8.25 to 1 on the 175's.....the 8.25 to 1 compression caused the ignition timing to be set back to 23 degrees BTDC versus 25 degrees BTDC due to detonation issues.
