HB112 Front Wheel Removal |
charles.link@aig.com
Topic: HB112 Front Wheel RemovalPosted: 11 Nov 2018 at 4:01pm |
I have a 1968 HB112 and I need to remove the front wheel. There is a metal hub in the center of the wheel. How do I remove this? Does it unscrew or do I need to pop it off somehow? Any help would be appreciated.
Dave H (NE)
Joined: 11 Sep 2009 Location: Western NE Points: 288 |
Posted: 11 Nov 2018 at 5:03pm |
the cap is pushed in to the wheel center. tap it side to side to work it out or use a large pair of pliers and work it side to side and pull at same time.
Posted: 12 Nov 2018 at 7:25am |
Thank you very much.
Mikez
Posted: 12 Nov 2018 at 7:43am |
Then when you get the cap off there's a collar with a set screw in it holding wheel bearings. Takes alen wrench to get set screw
Posted: 12 Nov 2018 at 7:54am |
That's good to know. The parts diagrams I was findind did not explain how to pull it all apart and I do not want to presume and start breaking stuff
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 12 Nov 2018 at 4:27pm |
Just make sure when you put the collar back on, you completely tighten it with the allen wrench - I would guess you know how I found out mine wasn't tight enough after using tractor for a while!
