HB112 Front Wheel Removal
charles.link@aig.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charles.link@aig.com Quote  Post ReplyReply Direct Link To This Post Topic: HB112 Front Wheel Removal
    Posted: 11 Nov 2018 at 4:01pm
I have a 1968 HB112 and I need to remove the front wheel. There is a metal hub in the center of the wheel. How do I remove this? Does it unscrew or do I need to pop it off somehow? Any help would be appreciated.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2018 at 5:03pm
the cap is pushed in to the wheel center. tap it side to side to work it out or use a large pair of pliers and work it side to side and pull at same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote charles.link@aig.com Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 7:25am
Thank you very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 7:43am
Then when you get the cap off there's a collar with a set screw in it holding wheel bearings. Takes alen wrench to get set screw
Post Options Post Options   Thanks (0) Thanks(0)   Quote charles.link@aig.com Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 7:54am
That's good to know.  The parts diagrams I was findind did not explain how to pull it all apart and I do not want to presume and start breaking stuff
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 4:27pm
Just make sure when you put the collar back on, you completely tighten it with the allen wrench - I would guess you know how I found out mine wasn't tight enough after using tractor for a while!
