Charging system on 716H
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Charging system on 716H
    Posted: 27 May 2018 at 8:23am
Is there after market part for the charging system on 716H.
Thanks
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:00am
humour me, going to be stinking HOT here soon,,, what's the engine on a 716H ? Most regulators can be bought...it's the 'alternator coil' under the flywheel that can be 'fun' to acquire. disconnect plug,ru at idel, you should get 25-40 vlts AC from the alternator connector. if s GOOD, it's just a bad regulator( or ign switch).
Jay
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 8:15am
Has single cylinder Kolher  engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 3:28pm
hmm, probably has a 3 by5by2 'brick of fluted aluminum' style regulator with 3 spades. 2 go to the Alternator coil the 3rd supplies DC to the keyswitch. Big thing is that it MUST be solidly grounded. I'd remove clean everything, then put back on. If not charging , you may have a bad ammeter. Put DVM on regulator side and run the engine, should get say 14 volts, more at high revs. If so, put DVM +ve on 'load' side of ammeter, it should be the same. If NO volts, ammeter is kaput.
I've actually got 1 or 2 of them here..'somewhere'. dang hot 90*F in the shade !
Jay
This page was generated in 0.180 seconds.
