d21 narrow front
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: d21 narrow front
    Posted: 20 May 2018 at 6:10pm
looking for a narrow front to put on d21 or light weight wide front
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 12:22am
Get out your torch and welder. I have seen one from a WC under a D21. Use your imagination.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 7:51pm
Use a 200 hollow,, cost redused wide front, they are a little narrower but use 1 inch spacers and it works that's the best route
Edited by DougG - 21 May 2018 at 7:52pm
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 7:19am
What weight are you trying to get down to
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 9:10pm
7500
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 9:11pm
have wide on it yet, but took out the heavy cast and made the plate for it to pivot on. it weighs 7800 right now
phil
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 7:13am
I had a D17 front end on my D 21 that originally came from Doyle Bounds in MO. Now Dustin Swall in CA. has thing. I had in down to 7500 lbs., but could not make weight and pulled pretty good in the 8000 lb class.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2018 at 11:50am
D 17 wide front works well.
That's what I have on mine
I would cut the axles down where only 2 holes remain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 7:55pm
do you know the weight difference in the d17 and d21 wide fronts
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 8:42pm
I was pulling in the 8200 lb class with the stock front end and cast in it.
I'm down to 7300 lbs with no weights or driver.
I also put lighter frame rails off an old Superstock on it at that time and 7.50 x 16 front tires.
My guess is it took about 200 lbs off comparing the 2.
You could lose more cutting it down tho
This page was generated in 0.250 seconds.
