CA shutting off
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Topic: CA shutting off
    Posted: 16 May 2018 at 1:38pm
My CA will shut off after running for 10-15 minutes, while driving and doing some light disc work. I already checked fuel flow- everything flows well in to the carb. There is also good air flow into the carb. Am I correct in narrowing down the issue to either the carb needing to be cleaned, or an electrical issue with the distributor possibly?
1947 C, 1949 B, 195? CA
60 series cultivator
fertilizer side dresser
2 bottom snap coupler plow
1 bottom plow, Cole planter
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 2:09pm
If it starts right back up after the engine dies I would suspect fuel flow such as something in the tank plugging the fuel riser inside the tank.  If it has to cool off before starting again I would suspect maybe the coil.  You will need to check for spark when it won't restart.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 2:52pm
yes, it has to cool off first.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 3:51pm
Sounds like replacing the coil would be a good place to start
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 4:15pm
Tank vented?
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 6:01pm
Originally posted by Stan R Stan R wrote:
Tank vented?
X2
These fancy new shiny chrome gas caps for CA's say they are vented but they don't work.  One of mine even has a sticker on it says vented.  Next time it dies, immediately reach up and loosen the gas cap and listen for air being sucked into the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 8:38pm
and the condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 10:09pm
Try to find a "made in America" condenser.  Yes, I'd try the coil first and see what happens. THEN change out the condenser.  Usually it's the coil.
