433T
740Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 740Miller Quote  Post ReplyReply Direct Link To This Post Topic: 433T
    Posted: 02 Mar 2018 at 8:13pm
Working on overhauling this motor. When pulling this down I noticed the two gears on the oil pump ride on a gear on the crank. Question? Is it normal for the teeth on the right gear not to engage the main drive gear? Confused? Me too. If I knew how to add a picture I would. Anyone's help would be appreciated.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 8:50pm
Crankshaft gear engages only ONE balancer gear.  THEY HAVE TO BE TIMED !!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 740Miller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 9:04pm
That's what I'm looking at a balancer? Is there a timing mark on these or do I need to mark them before I pull it apart?
Thanks this is my first 433
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 9:42pm
If you didn't disassemble the balancer you should just need the 2nd page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 740Miller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 6:03am
Thanks this helped a lot, so it says to change the bearings. Any ideas where to get the correct ones?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 6:36am
Four- 74009919 needle bearings and possibly four- 4008917 thrust washers from an AGCO dealership.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 6:37am
Ooops....74008917 thrust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 740Miller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 8:04pm
Thanks Dr. Allis, I appreciate the help
