190 3-point
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 190 3-point
    Posted: 11 Jan 2018 at 7:29am
I've noticed on most 190's and 200's the 3 point lift arms almost drag the ground when full lowered. Why would AC design it to go so low?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:07am
I'd be a lot more concerned about how HIGH it lifted, that if it drags in the dirt or not. XT's with big front tires and worn out 18.4 x 34 rears didn't lift any too high. If you've got 18.4 x 38's you won't be a draggin......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:34am
If I only had some 18.4x38's...
Tongue
Charlie
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 10:08am
The adjusters determine how high off the ground the are. If they almost drag, they are adjusted out too far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 10:37am
Mine are adjusted as far up as they go. They are maybe a few inches off the ground.
Charlie
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 10:52am
You need to move the arms a notch or two on the shaft,one notch probably will do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 11:10am
The "notch" or shaft spline location has nothing to do with it on a 190XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 12:01pm
The rock shaft is free floating if I remember right. The rams control the movement.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 2:52pm
Yea I was thinking about the tractors with the internal cylinders.
This page was generated in 0.093 seconds.
