Allis CA with B Finals |
1955allisca
Bronze Level Joined: 27 May 2014 Location: Ohio Points: 128 |
Posted: 24 Sep 2017 at 4:53pm |
Has anyone installed B finals on a CA to lose weight and make narrower? Just wondering if the final gears are the same ratio or how much faster or slower it goes and was hoping on a weight difference if anyone's done it thanks in advance.
Ken in Texas
Orange Level Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
No weight savings being the B finals aren't set up to adapt light steel wheels. Save weight by bolting on D10/ A Farmall Steel wheels with plain rims .to CA final drives.
Edited by Ken in Texas - 24 Sep 2017 at 9:56pm |
1955allisca
I'm running farmall centers now, I know Bs have cast centers I was going to make a 6 bolt hub to put on. I was also looking into changing the bull gears and then I think the hub from a CA may go in a b final but not real sure until I tear either apart. I know a B doesn't have a hand clutch in the axle and it's more than a foot narrower. They are also about 600lbs lighter than CAs and the rearend is really the only difference I can tell just trying to get down around 2000 empty
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2537 |
A B made after SN 18054 should have the same hub as a C. According to the parts book anyway.
AaronSEIA |
Ken in Texas
B flanged Axle part number 212806
C flanged Axle part number 210220 Different part numbers don't interchange according to my parts book anyway
Nathan (SD)
Orange Level Joined: 11 Sep 2009 Location: Day County SD Points: 1244 |
Ken in Texas
There is one more if you use the first B axle stub with the splined 5 stud adapter hub,
AaronSEIA
Maybe I should have specified, they use the same center for the hub. Looked that up 30 seconds before I had to leave for work and didn't get to research it in depth.
AaronSEIA |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4454 |
Ratios are different. Things will bolt up if you make provisions to change the fender mounting rails. However the one that said use D10 finals, that will not work. B,C & CA have out board band brakes, whereas the D10/12 have inboard shoes and the bolt pattern is different.
