ac130 belt |
brucea
Joined: 06 May 2015 Location: United States Points: 3 |
Topic: ac130 beltPosted: 06 May 2015 at 11:57am |
is anyone else having problems with models breaking belts on my 5th one in two years dealer says they can find nothing wrong with it only cut about half acre of grass
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25163 |
Posted: 13 May 2015 at 6:21am |
Has to be an 'alignment' issue. ANY rider/mower will bust belts if the belt doesn't run properly. It should run 'flat against the 'flat' pulleys, near center if possible AND at 'right angles' as well. Anything 'bent' even a little will cause a problem.
You may need a few 'extra' eyes to see what's really wrong.Look from both side of the tractor,have someone slowly turn the blades to see how the belt moves. If electric PTO, do not engage at full speed! The 'shock' can 'yank' the belt,hit a pulley 'wrong' and nick the belt, Do that a few times.....whamm, busted belt. Also check the deck to be straight and plumb. Again this is an 'alignment' thing. Whacking tree roots a few times can bend the deck and or mounts juuuust enough to throw off proper alignment. Knowing what belts cost, take a day or more to see WHY it's happening, might only take 10 minutes with a hammer to re-align the culprit. hoping this helps Jay |
brucea
Posted: 13 May 2015 at 9:41am |
thanks that is what i was thinking been looking at that they told me to engage the mower full throttle seemed to me alot of strain on the belt
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 13 May 2015 at 10:43am |
They're Nuts to tell you that!!! Never engage them running much above idle! Shock load snaps them into!!!! |
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Posted: 07 Jun 2015 at 9:08pm |
I agree they are nuts. especially if it is colder temps....
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4062 |
Posted: 07 Jun 2015 at 11:08pm |
make sure you are putting onthe proper lenght to tight breaks them also make sure all the spring loaded idlers move proper because as the deck goes through alow spot the distance is longer between pulleys i would look at pulleys pivot points
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 28 Sep 2015 at 8:42pm |
what size belt goes on the 46" model? The manual does not tell me
Charlie
NorthernChill
Joined: 01 Jul 2017 Location: Elk Mound WI Points: 7 |
Posted: 01 Jul 2017 at 9:30am |
Simplicity 1719911SM
V-BELT HA 117.0 AR runs about $35.00 to $40.00 I dont know if there is a cheaper belt that you can use but if there is let me know |
