170 temp issue
tractorhead9542 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Topic: 170 temp issue
    Posted: 11 Jun 2017 at 8:43pm
Have a 170 that keeps running hot on the gauge. Let it be known...recored radiator, new water pump,thermostat, gauge, and sender. Thermostat temps out at 160 +/-5. Block is 140 at front and 180 in rear respectively. All while running during work. Gauge kicks up pretty quick and stays mid red no matter what. Ohmed and replaced sender again with same results. ???
The road to nowhere...leads to me
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:23pm
That is why I go to auto supply and buy a mechanical gauge.   MACK
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:26pm
Have you tried a new Radiator cap, my 190XT did the same thing and the cap was not holding pressure.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:27pm
Block temp seems good. Is it pushing water out of the rad or any other symptoms?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 6:08am
New radiator cap. No coolant boil over. I think the gauge is too sensitive. Or...that is the hottest spot in the block at the rear. Maybe some blockage?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 6:10am
I'm going to run it again this afternoon. Never thought that that radiator cap may not be good even though it's new.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 11:16am
Does your fuel gauge work correctly. I'm having a similar issue with a 6080.
This page was generated in 0.075 seconds.
