wheel seal
marv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marv Quote  Post ReplyReply Direct Link To This Post Topic: wheel seal
    Posted: 21 May 2017 at 8:36pm
Rebuilding a 42 B with front cast wheel hubs. My question is should the inside seal spin with the wheel or be locked on the spindle?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 9:01pm
The seal should be fixed in place; if it spins it will leak,,,and may cause other damage.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 9:23pm
There are different styles of seals and they can go either way. All need to be tight in the hub.
marv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marv Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 6:11pm
Thanks, the seals are the felt with a notched inner ring. I'll have to figure out to lock to the spindle.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:32am
Sounds like it's like the seals for my D12.  You drive the seal onto the spindle before mounting the hub.  However, my experience with aftermarket seals of this type is that they will not drive onto the spindle - the ID is too small.  If you have an aftermarket seal and it won't fit, get a genuine AC/Agco part instead.
This page was generated in 0.110 seconds.
