226 Crank Cap Specs |
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jul 2010 at 5:10pm |
I need the torque specs and order to torque my main caps....had to loosen then up to free things up to change out the rear main seal...pretty easy after that. Just need to tighten things back up....also the torque specs for the pan gaskets if there are any.....thanks ahead of time.
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Mike(SEIN) ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: RUSH County IN. Points: 143 |
My I&T manuel says 85 ft lbs , I dont know if its any different for used bearings.
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25182 |
The torque would be the same, no matter the bearing.
I am still confident of this;
what about pattern to torque them in?
Jason(OH) ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Jeromesville, O Points: 188 |
Torque starting in the center and alternate side to side until you reach each end.
