Dash in 200 ???? |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8646 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Apr 2017 at 8:34pm |
I have a allis 200 with I think year round cab. My question is can you slip the top cover of dash out from under the cab bracket that goes over it. Hope that's explained good enough lol. I want to hook a wire up behind dash.
Thanks |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5576 |
Should be able to. Even with a factory cab, it is a tight fit, but it came out. I put 1/4" fender nuts on mine. 1/4" bolts hold down the cover tighter than screws.
Ok thanks
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1907 |
Put your steering down low and on a 200 extend it out and if nobody bolted anything else in the way you can slide it into the cab.
Ok thanks again
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Most cabs have a removable plate on the front around the dash cover.
